Viper87227
- Jun 2, 2004
Just got my system set up with this board today, and it's giving me a hard time.
At first I had a hard time getting windows installed, and traced that to my board not liking my ram in the yellow slots. Put them in the oranges, and things went great. Installed windows, drivers, ect. Ran StressPrime 04 for an hour and a half just to make sure things were good.
After things were workin good, I decided it was time to flash the bios. It shipped with a 12/15/05 bios... no good. Got the latest official bios from DFI, 4/6. Flashed it, everything went smooth, so I decided to hit the memory OC and find my max. I was already farmiliar with what this ram did on my Asus SLI Premium, so I was able to proceed easier. I made my timings what they should be (3-4-4-8), set volts, ect. Put my CPU at 5x multi to rule that out. As I knew what my ram could do, I was upping 20mhz at a time, and then memtesting for 5 minutes just to make sure the settings alteast took... wasnt looking for stability at this point. Was looking for a max. So, I made my way smooth sailing up to 280mhz... the max stable from my asus board. Tested for 5 minuets with no errors, so I was then going to go to 5mhz at t time , and test for longer. However, I didnt make it that far. Rebooted, and I get a hard lock after it decets CPU and 2gig ram. Rebooted to try again, same. Fine, doesnt like that, time ti tweak timinsg a bit. I figured I woudl try the soft reset to get into tbe bios. Switched the jumper, let it sit for 30 seconds, switched back. Still got a hard lock. So, fine, I decided I would do a total bios reset. Swapped the jumper, pulled the battery, let it sit for 30 seconds, and now I get a new problem. Turn the system on, takes a few seconds for drives and whatnot to fire up, then the video cards bios pops up for a second, then the system resets... and just does this over and over again.
. Tried a cmos reset again, let it sit for around 5 minutes this time. Same deal, I cannot even hit the post screen now... the system reboots right after showing the video bios info. Anyone know another way I can get around this?
