yea thats pretty high.first you need to pull it off and clean and replace the thermal compound on the heatsink and chipset.thats if your fan is not failing and gringing and making all kinds of abnormal noise.if its been on for a ling time you may want to replace it all together with the evercool model alot of people are using and most say it cools better than the original.dfi street has a feature on all the instructions for replacement.its pretty easy.this is one drawback with these boards as you cant put a larger more powerful setup on the board.a design flaw for sure.if the unit you have is still good and not to old you can just clean and reinstall it with artic silver 5 or ceramique by artic silver.the replacement fan is better but not by a whole lot.if its still good save some money and reinstall it.
because my case (gigabyte aurora) blows almost zero air over the chipset, my temp is over 60c at idle. i dont know what it is in games, but i can guess. been like this since december on my ultra-d. absolutely no probs. stock cooler, stock goop. but thats probably because its a dfi board. i could take it out and hammer nails with it all day, put it back in, and get my 50% overclock.
