I have a few reasons I don't want a laptop. First, I can't do it myself. Second, I can't replace parts. Third the kind of laptop I would need to equal what I want would be around $5000 instead of the $3000 I'm looking for.
I do lan parties all the time. The reason I want one like this is, so I can open it up in the airport etc. I'm beginning to think I'm going to have to do it myself.
Just about all monitors support standard VESA mounting, all you need to do is drill 4 holes in your side panel, remove the monitor from its base, and screw it to the side panel through the 4 holes you just drilled.
Sounds like you are a candidate for a mac.
ROFL.. jk.
Anyway, if you want something built in.. custom is the only way to go with what you want. Otherwise, I'd just go with a mATX setup in something like a microfly or lanbox. Its fully upgradable and can pack a serious punch. Then just lug the LCD with you.. its really no hastle. If you want smaller, a shuttle or ITX size would be even better.
more like a iMac essentially what it is. a screen glued to the side of a thin case.
An expandable all-in-oneis it possible? We made sure the Gateway Profile 6 can grow with an organization by leaving room for future upgrades. A full-height PCI slot, half-height PCI slot and full-height PCI Express x16 graphics slot all make expansion easy. And multiple memory, optional integrated Expansion Possibilities wireless, hard drive and CPU options allow you to configure the system to meet a variety of needs.
One rule. The only game you can play at airports is Counter-Strike. As a terrorist. On the plane level.
