What makes you say that? And for what use?
Factory calibrated, built-in LUT, more inputs, OSD.
Dell has an OSD, but more input lag by 250%. The HP only has DVI and DP inputs, but that's pretty much all you need. It's more barebones I must admit. However, if you want to calibrate, why cheap out on calibration software when you are buying a $1200 monitor anyway?
It's all preference and the deciding factor of initial cost I suppose.
For around the same price, U3011 > ZR30w.
If you play FPS games and have good eyesight I disagree.
Mine showed up today. I'm liking it. Still need to make the colors match, but fabulous to have all that pixel space again. Will do some gaming on it tonight.
Hey guys, hoping for pointers, what video card should I be looking for in black friday/cyber monday sales to power mine once it arrives? I currently have an e8400 cpu and a 9800gt video card. I figure I'd benefit from some more juice in the video card department. Basically I've heard that my cpu will bottleneck higher end ones, so I'm wondering what the top end I could see improvement with video card wise is before I get bottle necked.
Thanks.
Zarathustra[H];1036466403 said:I think you may have posted this in the wrong thread...
After seeing the pics cant wait to get mine Friday!!!
Santa?
So i purchased this monitor on friday the 19th with an expected delivery date of 12/17. Just checked my email and got this:
Ship date
Nov 22, 2010
Estimated delivery
Nov 24, 2010
Awesome, but now I need to get a saw to cut the shelves down on my desk a bit so the 30incher can squeeze in there
Same here on the buy/ship dates. Can't wait as this will be a nice upgrade from my 5yr old 24in Samsung. Only problem is I work that day and won't be home. Wonder if a sig will be required.
LCD's don't have a linear response. This means if you send twice as much current to a pixel it won't open twice as far and become twice as bright. This is in turn compounded by the fact that the color filters used to turn a monochrome 7680x1600 panel into an RGB 2560x1600 device don't produce pure light at exactly equal transparencies. As a result the monitor needs to do a bit of math to know how much current to send to the transistors controlling each pixel to create a given RGB color; the magic numbers plugged into the formulas used to do that are stored in the lookup table. Adding to the joy, each monitor has a slightly different response pattern (so a single calibrated result won't be perfect for other displays); and the color balance changes as the panel ages so even a perfect factory calibration will be slightly off after a few months of use.Zarathustra[H];1036463776 said:I have also read about the LUT.
Can anyone - in laymans terms - explain how a monitor uses a lookup table and why?
its here, its huge, its awesome, i love it.
