just got mine, rev A01 made in Mexico
no dead pixels or tinting issue (that i can see)
i can happily retire my NEC 20wmgx2
also any tweaks for the sharpness setting? or should i leave it default
any obvious tinting?
Well the 499 deal is over *sadface* so I won't be getting one until its atleast 499.
When you guys got your exchange units, was the return instruction (label + paperwork) in the box or in a separate letter ?
Just a percentage by itself does not mean anything. So when someone says 72% AdobeRGB they mean the monitor can display 72% of the possible colors in the Adobe RGB colorspace.I'm confused by all the gamut talk about this monitor. Can't seem to get a clear idea of all that 72%, 110%, 100%sRGB, 96% AdobeRGB etc. Can anyone explain it to me please?
Could someone tell me how big the space between the stand and the screen is?
I'd like to fit my center speaker in there which has a height of 117mm.
What is the verdict for this one? I'm on the fence about buying. I've read about 70 pages here and all of them at the Dell site. This would be my first Dell product and I'd rather not gamble with 500-600$ purchase.
On the U2410 I would suggest the following:
Input Color Format : RGB
Gamma : PC
Mode Selection : Graphics
Preset Modes : Custom RGB
/QUOTE]
Thanks, but why the Custom Mode?
There are two colorspaces of interest here, AdobeRGB and sRGB. Adobe's is the 'wide gamut' colorspace, and sRGB is the standard gamut colorspace (very close to REC 709). As the names imply wide gamut is a larger gamut and has more colors in it that standard sRGB gamut. So 100% sRGB = 72% Adobe RGB. The only people who should really have any interest in Adobe RGB are professionals who deal with print and sources that require wide gamut. Almost everyone else needs standard gamut. Displaying standard pictures and video on a wide gamut mode / screen results in wonky and overblown colors.
All DVDs, Blu-Rays and 99.9% of the content on the internet and every other source you are likely to encounter is 'standard gamut' or sRGB - you want a monitor that is as close to the sRGB standard as possible.
Most monitors can only display one colorspace, but this Dell can actually (mostly) correctly switch between both color modes, although in sRGB modes the A00 revision had some issues, and it does add a little bit of input lag.
When you guys got your replacement LCDs, did it came in different packaging from the original? I got my U2410 replacement earlier today and the packaging is different. The LCD isn't held by the Styrofoam like my original U2410 were. It's just held by different pieces of cardboards inside. Did Dell changed packaging here or they gave me a refurbished? Basically the packaging doesn't look very sophisticated like my original U2410s. It's making me suspicious and all.
How does one know if they have got a refurbished LCD or not? Also I notice the the instruction paper wasn't completely inside the box. When the deliveryman dropped off the item, I noticed that part of the instruction paper sticking partially stuck outside the packaging.
You sir got a refurbished unit.
May I ask how you know this?
Well if it isn't new and sealed with calibration report/instructions/cables/cd-rom etc...then it is obviously a refurbish.
Since you got it though you might as well test it...
I would say its pretty obvious. No styrofoam means not the original packing. I've never seen laptops and LCDs packed without a styrofoam casing around it.
And I'm pretty sure they don't even refurbish, they just send the ones coming back, right out, hoping some novice buyer won't notice any problems.
Test it though, but I'm sure its not a good one!
Also, in some previous posts you will find someone mentioning how Dell reps told them the exchanges sent to them would be refurbs. So they are in fact sending out refurbs as exchanges.
