I have a pivot monitor that does the "slightly tilted" thing as well. I just fold a piece of paper over and over until its thick enough to lift it to a proper level. Not a pretty fix, but a fix none the less, without potentially forcing it to break.
When using a gamma of 2.2 and a color temperature of 6500K, the 4chan background is supposed to be an obvious light yellow, not almost white. From the pictures, it looks to me like the one on the left has too much blue.llmercll said:For instance 4chan has a very obvious light yellow background on my A01. on the A00 it's still light yellow, but you need to really look to distinguish it from pure white, found in some of the pictures. The photo I posted above shows it really well, if you look at the white "MALES FEMALES" picture, and compare it to the colors around it.
1. the monitor is tilted very slightly clockwised. but i cant tilt it back counterclockwise because its at it's maximum. 5mm height difference between the left and right end. is this common for most users? if not, u think they allow exchange just for the stand and not the panel?
someone in another thread confirmed it is only 20.3 inches wide
I think you're confusing people asking for 2211H specs in a 2311H thread. The 2311H is indeed 21.5 inches wide, no idea about the 2211H.
you are probably right - didnt realize - sorry for the confusion...
1) Mine seems fine. I guess if you want to "risk it," you can slightly force it to pivot (there is give on mine) to the other side, it isn't a hard stop on mine preventing it from pivoting counter clockwise. I did fix a tilt on a PX2370 I tried by forcing the hinge this way (and that monitor has no pivoting hinge).
2) Digital to Digital connections tend to have better IQ, especially in that they tend to be sharper and less blurry. If you don't find the picture currently blurry, then I guess it is fine. Whenever I try VGA on a LCD, I tend to find the picture slightly blurry and unfocused.
3) Not unless there is some bug with your current drivers. But newer drivers may or may not fix other bugs/add features/or improve performance of your GPU. Likewise they might add issues.
thank you for the advices!
but i still have this shimmering vertical lines on a Paint full black screen. like some interference or some sort. any idea what might be causing these? the VGA connection cables?
hd 5850 via dvi on an A01 panel.
have you tried another VGA cable? My issue was solved by changing cables =p
or if you have a vga -> dvi adapter you can try that to see if it's the vga port on your monitor that's giving you problems.
Does anyone else have a portion of their settings, such as Pixel Clock, grayed out? How come I can't access them?
I am pretty happy with my monitor but the image quality from my Gateway FHD2400 still seems better. There seems to be a kind of film I can't get rid of on this; I'm not sure if it has to do with the glossy screen of the Gateway providing more pop. Also, I don't know if it's because of lack of 1:1 on the Dell, but text looks a little bit blurry (I set my sharpness to 50).
And is it just me or are the "calibrated" settings for this found throughout the web horribly wrong? All of them seem to look either too cool or have too much of a color cast. (I am pretty sure I know what 6500k looks like, since my KURO is calibrated to that.)
1. i've read some displayport>displayport issues such as the monitor going to sleep mode. anyone has that problem?
Today I've received my U2311H Rev. A01 and unfortunately it has a very unusual defect. If I view it at a normal angle it looks fine, but otherwise a huge bright horizontal line is visible (on any background)!
Have any of you ever seen something like this?
whats the difference between a00 and a01?
I have the A01 and an NVIDIA NVS 5100M (HP EliteBook 8540p). So far no issues with DisplayPort to DisplayPort.
For those of you who are owners of this monitor, and that game on it (FPS, RTS etc.), how do you find it for gaming use?
I'm looking to buy one, primarily to be used for gaming.
haven't had any problems with gaming.. it's great
The lcd screen itself is about 20" wide, but when you include the frame it is 21.5"
Uh, I have a small question regarding the 360 useage on this monitor.
We all know that HDMI has better quality than VGA (At least what I've observed on my older 22" monitor). Is it possible to get some sort of HDMI to DVI converter/adapter or cable and play the 360 through the U2311H's DVI port? I know I'd need a DVI switchbox since it's also used for the PC but that's easily bought.
I have an old Viewsonic VX2260WM that I want to get rid of in favour of the Dell for gaming, but just wanted to make sure I could do this.
