Europe though, right?
Saint Louis, MO actually
Also, there's a video review of the U2311H up on YouTube if anyone has missed it: http://www.youtube.com/watch?v=s4Q78-G1xHA
Is it really worth it to replace my Samsung XL2370 (LED backlit TN) with this monitor? My biggest problem is that when i lean back in my chair dark movies, and maybe dark games are the most problematic (for example Ninja Gaiden 2 on X360), they are almost unenjoyable, thanks to the TN gamma shift they become very dark, and bad looking, if I stand up they'll look good from an upper angle...
On this video review black almost always looks bad, if you don't watch it from the center.
Has someone tried darker movies/games on this monitor already? Isn't it disturbing if you don't watch it from head on? The screen doesn't lose the details from non-center viewing angles? Also won't darker things looks washed out? (leaning back is the most important, for movies and console gaming)
Is it still much better than a TN panel like this?...
just to add to your confusion - more lines and more pixels is more important than the ratio when thinking about productivity, though I appreciate your dilemma. I find 16:10 more natural.The second is for CAD and programming work, as I need a maximum of workspace
Have you checked the price of the ZR24W direct from HP in Sweden? Maybe one 1920x1200 is a better compromise than 2x 1680x1050? and you could choose 1920x1080 as the res for gaming to take a little of the load off those graphics cards (it's usually an option, 16:9 has been popular for ages)
Where do your priorities really lie? frame rate for games or productivity?
EDIT: and if you decide to go 1680x1050 look up the price of the Fujitsu P22W-5 ECO IPS, it's probably marginally better than the Dell.
Well, I used to have a 16:10 monitor but now I mostly use my 16.4'' 1920x1080 laptop. I miss the extra vertical space, but it's hardly a dealbreaker. Especially since I am considering going the same route as you and buy 2 1920x1080 23''. Besides, for you 1920x1080 is actually an upgrade in vertical real estate. You get more 30 pixels to play with than you get with your current monitor.I know the higher the resolution, the better, but I'm generally bothered by 16:9. But, as the market seems to be heading that way, and that it might not just be fad, maybe one might as well get it now. I'm buying these monitors for two years of use minimum. I've had my current one for nearly two years, and the only reason I'm changing is for the bigger workspace. It's still a very good monitor, and it's generally a pretty stable market with high second-hand values (screen is in very good condition, no dead pixels). Do you think I could get €200 for my T220HD? If so, I wouldn't hesitate getting a second monitor right away.
Again, even for productivity, you'll benefit from the increased resolution, despite it being 16:9. Don't worry too much about sidescrolling, you'll just adapt. You might have to play with your mouse definitions for a bit, but you'll get there.I might as well go for a higher resolution, as I'm stepping up from TN to IPS. I'll probably want to get 23-24" eventually. I've noticed that I slowly get accustomed to the workspace I have available, and in the end, want more. I'm trying to be a little proactive and delay the next "upgrade". Before my Samsung, I had an ancient 17" LCD from 1998 (don't remember the brand). Sticking to 22" 1650x1080 doesn't feel like a major upgrade, and buying a single 24" monitor doesn't really give me the same value for my money (even though I could step up the quality). Don't get me wrong though, if I had the budget for it I'd get dual 24" monitors.
My priorities should lie in productivity, and associatively in multitasking CAD and programming. But I sometimes find myself gaming and watching movies/TV series either way, so I'm not going to deny those two as uses for the monitor. The aspect ratio only becomes somewhat of a problem in games. I don't think the step up in resolution is that much of a strain on the video cards, I can always reduce antialiasing. I'm a little worried about sidescrolling between the monitors though, it's a pretty wide workspace.
That makes a world of difference to me. I can't tell you how much happier I am with being able to have 2 apps running side by side. The extra 200-something pixels when comparing to 1680x1050 are incredibly useful.I'm going to go ahead and order two Dell U2311H from Dustin right now, before the sale ends; thanks to Sweden's awesome return policy laws, I have 14 days to decide if I want to keep them or not. And Dustin is a good reseller. I'll just keep them in their packaging until the tint issues and such are more resolved; I expect there to be more reviews and comparative analyses (especially with the 2209WA) soon. Either way it would be great to not have to use alt+TAB anymore.
Dell used to have a lottery just like that too. But you don't have to worry about that now. It hasn't happened for a while and since IPS panels are a lot cheaper now, it wouldn't make much sense.How does Dell generally handle panels? Do they have a lottery like Samsung did with some of their monitors? I really don't want them to sneak a PVA panel into mine. After reading this thread it seems most people got similar panels.
Also I heard that this monitor is only 8 bits (6+2), isn't that more like a TN in terms of color reproduction? The problem with 6+2 bits are that the dark shades of gray doesn't look that good like they should on a real 8 bit panel, dark movies and games are suffering from this.
Is there a big difference between this monitor and 2209wa in this aspect? Or this isn't that big a problem with IPS panels like on TNs?..
IPS panels are all true 8 bits. TN panels are 6bit+2.
Are you sure about this? At the shop I wanted to buy an U2311H they said that they are sure it is 6+2 bit only, they said the same about LG W2220P a few weeks ago, for example 2209wa is 8+2 bits.
If it's sure that it is true 8 bit, I'd buy it...
It's an IPS panel, that's true 8-bit.
One thing that I noted was that I believe he used out-of-the-box settings. Based on the TFTCentral review posed just after it, out-of-the-box means 75% brightness. TFTC also says that the dark level decreases (gets darker) as brightness goes down. This leads me to believe that if you lower the brightness to a more color-accurate level, that the purple/orange tint will be much less severe and probably minimal (especially in the 20%-0% brightness range). It's also a worst-case scenario" full black screen when all lights off. I don't believe anyone should use and LCD with the lights off as I have read small studies of increased eye strain in such conditions. Maybe you could e-mail the guy, ask him to follow up on such settings and let you know what he sees. I think a few of us would be interested in what you find.
Ooo... I missed that part. Is there anyone that can tell us what the luminescence is at 31bright & 60con?Well, he said he used 31 brightness, and 60 contrast in the video review, which is probably under 120cd/m, and I don't think many people will use it at lower settings.
Many games and movies have darker scenes, where is a lot of black, and dark details in the backgrounds, so I'm afraid that if I don't watch it from head on in this cases it could be even worse than a TN panel (only in this case, of course, but this matters for me too).
Also I'm using my monitors usually around 170-180 cd/m setting, maybe my room is too bright, but 120 cd/m calibrated settings looks too dark for me (at least on TN panels, which I've had so far), it could be OK for browsing and text editing, but for games and movies this is the minimal setting which is looking good for me. So, if I understand right the glow/tint problem could be even worse at a setting like this, it doesn't sound that promising. Or can an IPS monitor generally display better quality, brighter images even at a lower brightness level?
Ordered June 14th, delayed to July 14th.![]()
what's the issue with Dell.. are they having problems with the panel display manufacturing? I'm thinking about ordering one but I'm moving in a month and I don't want it to be shipped to a defunct address
Hrm, for some reason the U2311h was taken off of Dell Small Business today. I called them and they didn't know why it was taken off. Damn, I was just about to order two of these to do eyefinity with my NEC EA231WMi! Had a 20% off coupon + 10% off BCB too!
Do you think this will work well with the EA231WMi since they use the same panel? I'm hoping since the panels are identical that Eyefinity will let me use bezel comp.
My guess is that they are smart again and are doing what they did last year with the 2209WA: when the shipping is going to be delayed for a month+, take it off the site to stop teasing people with something they can't deliver right now.
Does the NEC have a DP?
I see the AG as being very typical, I think it's to an ISO standard and all the IPS panels are manufactured by LG...
Quick question: Is there a way for the computer to auto-detect the vertical pivot on the U2311H and adjust the display to "portrait" mode accordingly?
I have having to go into the Win 7 display settings. I don't change the monitor to portrait mode that often, but it's still annoying.
Does this monitor have the "dusty/grainy" look that almost all non-glossy screen monitors suffer from? I don't know how people can stand looking at dusty speckles all the time.
Just reiceved my replacement after a whole five weeks. Sheesh. And yep, i got backlight bleeds and tinting problems:
http://i651.photobucket.com/albums/uu234/LyricSuite78/Picture1.jpg
http://i651.photobucket.com/albums/uu234/LyricSuite78/Picture3.jpg
Those were taken with a webcam. I'll try to do better later, but you can really see it.
