Dell Small Form Factor - 745
chal2les
Hey guys,
I am trying to upgrade my 745 to have a more powerful graphic card, but was wondering which one is available?
Thanks!
It depends on a couple of factors.
1) Your PSU wattage and amperage on the 12v rail
2) What type of slot you have on your motherboard (AGP/PCI-E/PCI)
3) Size of your case/mobo and fit of the GPU.
I believe its a 275 watt power supply, pci-e, and requires a half height card.
Now how much of that wattage is on the +12V rail? Or how many amps are on the +12V rail? Or better yet, take or find a pic of the PSU label if you can
Sapphire 3650 is your only option. That power supply won't be able to handle a 9600, not to mention that there aren't enough power connectors to handle the molex -> PCIE power connector - there are just enough connectors for what Dell puts in the box.
