Welsper
- Jun 30, 2005
I use my former computer (Dell Dimension 4500) as a fileserver/test computer. Recently, the PSU has been making a buzzing sound, which I traced to the fan on the back of it; I am wondering if I can replace the PSU with a standard Cooler Master unit I had from a previous build (350w for the CM, 250w for the Dell), but I have heard that Dell uses (or used to use) a proprietary pinout for their PSU to mobo 12v connector, it looks the same as a normal PSU plug, but its wired differently. Any answers? If it helps, it was built around June-August of 2002. Thanks for your help
