Dell Precision T3400
slugger_2003
Anybody know which motherboard is in this PC and if it would be compatible with GeForce 8800GT onwards and/or ATI 4850 onwards?
Everything you could possibly want to know can be found out by putting in your service code at the support section of the Dell website. It might even give you a clue as to who actually makes the motherboard if you look at the parts list. They are mostly Asus custom boards, or they used to be. If you can determeine what chipset is used you will know most of what you need to know about the board.
http://accessories.us.dell.com/sna/DellPartsFamily.aspx?c=us&l=en&cs=04&s=bsd
A 3 second look at the T3400 at Dell.com tells me it has a 16x PCI-e slot and so either of the two cards you mentioned will work.
The power supply is a different story. Very marginal. Only 375 Watts and I cannot determine how much of that is on the +5. I would grab a Corsair 550 next sale/rebate that comes along and you should be good for any card present or future you put in there (450Watt might be sufficient as well but it has to be a good one with most of the power on the +12). Moral of story, be ready to add $75-$100 to the upgrade budget. Good news is video card prices are now reasonable again.
