StinkyMojo
- Sep 16, 2004
I know what you mean man.. I barely had enough to squeeze out a box.. consider me luckyPrkChpXprss said:Argh. I was waiting to get paid so I could get this. Sucks to have missed out.
nomar said:I had wanted to get in on this deal and put the computer in a 2u rackmount case I have. I guess with that huge heatsink, that won't work. Is it almost the width of the whole case?
amd ati FO SHO said:lol joe, your last couple posts are useless. if you really believed that people shouldn't post useless stuff then; why didn't you just ignore the responses in the first place?
tom61 said:I wouldn't worry to much, considering Dell the deal will be back. Typically hey rotate discounts, at least in Dell Home, so after it goes up for a week or two, it goes back down. Still, even though it's $50 more, it's still a good deal.
joecool234 said:Last I checked, the system is $150 more, at a minimum.
...and after seeing the build quality of this machine, anyone that thinks Dell is crap is a fucking MOE-ron.
Anyone try to plug the monster Promise Fastrak SX4 into the box? If so, does it fit? I'm looking to set up a 1TB Raid5 file server now that Tivo allows you to archive yo shiznit.
cybertron said:how would you, personally, work those drive space? I was trying to think of how i could get more drives in there but at best i'm only seeing a possibilities of like 5 if you can some how manage to get 2 drives in the floppy bays... unless there are only one, i cant remember now.
6 if you remove the CD-ROM. The case has 4 x 3.5" bays and 2 x 5.25" bays.cybertron said:at best i'm only seeing a possibilities of like 5 if you can some how manage to get 2 drives in the floppy bays...
Yea. Normal. I think 48x or 52x.StinkyMojo said:hey for the guys that own this: are you experiencing loud cd-roms? I just got my server and powered it up for setup, I put my server 2003 enterprice eval in and the cd-rom buzzes.. not too loud but kinda makes me worry. just wanna make sure this is normal.. thanks guys.
i got a maxtor too :/Jovian said:Just got mine all set up and installed with Win2k. The hard drive it came with was accually a 80Gig Maxtor not hte seagate. Kinda dissapointed in that but hey it was only $10 more for 40 more gigs. Everything seems great and like previously said quality is top notch.
pxc said:i think he complained more on the principle because obviously the hardware to make something similar is going to cost more at newegg. LOL
kleptophobiac said:Kernels 2.6.9 and 2.6.10 picked up and ran beautifully with this system. Be warned that if you want to run X for some reason (I needed it to configure mythbackend - it has no way to configure it otherwise) then you'll be stuck with the vesa drivers, as there isn't an accelerated driver for the i915 chipset yet.
ziddey said:aghhhh
could a mod please change the title to say [dead]? it gets me every time![]()
Note: For server use only; CANNOT BE USED AS A DESKTOP.
Dell does not support the use of a graphics card on the SC420
Falls Included said:its shitty how there are no XP drivers...anyone find any decent info on this yet?
you offering?amd ati FO SHO said:will you pay for shipping?
pxc said:Instead of voiding the warranty (motherboard, at least) by modifying the slot, I modified the PCI-E card instead. Of course I don't recommend doing this to a card actually worth anything...
http://www.notveryserio.us/pix/x300se-x8.jpg
I used a cutting disc on my el cheap-o dremel clone and yes, i just sliced through traces, contacts, etc without regard. The system is going to my brother (with a regular 84W P4 3.4GHz... I kept the 3.4F) and he needs a DVI port. The x300SE is perfect since he doesn't play games at all.
And last night, for less than 2 hours, dell had a pretty awesome deal on the Dimension XPS for $519 after $1250off coupon:
Dimension XPS
Pentium® 4 Processor 550 with HT Technology (3.40GHz, 800 FSB), Microsoft® Windows® XP Home Edition Qty: 1
Unit Price: $1,769.00
Dimension XPS Pentium® 4 Processor 550 with HT Technology (3.40GHz, 800 FSB)
Memory 512MB Dual Channel DDR2 SDRAM at 533MHz (2x256M)
Video Card 128MB PCI Express x16 (DVI/VGA/TV-out) ATI Radeon X300 SE (6800GTO was $290 extra)
Hard Drive 80GB Serial ATA Hard Drive (7200RPM)
Floppy Drive and Additional Storage Devices 3.5 in Floppy Drive
Operating System Microsoft® Windows® XP Home Edition
CD or DVD Drive Single Drive: 16X DVD-ROM Drive
Sound Card Sound Blaster Audigy2 ZS (D) Card w/Dolby 5.1, and IEEE 1394
etc
$1769 - $1250 = $519
I got one of those.![]()
