Dell power supply ?
the snake
can anyone give an idea on the total output of this Dell power supply, a friend just got a new Dell PC and he may want to upgrade the GPU in it, but i am not sure how large of a GPU he can put in there ?
That PSU is fairly close to being a regular 400W to 450W PSU since it has 385W on the +12V rail or ~32A on the +12V rail. ~32A is generally found on 400W to 450W PSUs.
What's the rest of the specs of the PC?
............waiting for info from friend
Also, please tell us the numbers underneath the reverse R and normal U logo. In your picture, it looks like it's covered by the flash/light
Well that's a relatively new system. Most likely you can upgrade to a HD6950 or GTX 560. You may even be able to go to a 580, although that will push it a bit.
I highly doubt those cards can be trusted with that white box psu. gtx 460 or 6850 is the most I would ask of that psu.
You have 385W of 12V power (most stuff in a modern PC runs off 12V)
Afaict you have a CPU with a TDP of 95W, allow 50W or so for other bits and peices (drives, motherboard etc) and a bit of a safety margin and you have about 200W left to spend on the GPU, you might get away with going a little higher than that but you would be pushing the PSU right to it's limits which is generally not a good idea.
if you look at the top right hand side, it says 460 watt. Upgrade, I would use at least a 500 watt or better. a good GTX card normally wants around 600watts
A good GTX card needs only 500 watts. TDP of the 580 is 250 watts. Actual power consumption of the 580 is around 200 watts not overclocked. To say it needs a 600 watt power supply is BS. So he's fine with going to a 560 or 6950.
Most current Dell power supplies are actually fairly good quality, and can be trusted to put out their rated specs.
