I'm onsite currently initializing a new RAID 5 array on a customers server, a T310. The server originally came with 3x500GB SATA drives that are hot swap. I have replaced those with 3x500GB SAS drives of my own that are not under warranty. I am planning on doing a bare metal restore of SBS 2011. If the restore works, would I be able to pull one drive at a time and replace it with the original 500GB SATA drive? I know Dell says they wouldn't recommend it and it wouldn't be supported, but has anyone done it? Should it work or will I get blue screens?
The original drives are Dell 500GB SATA 7200RPM hot swap
The drives in the server now are Dell 500GB SAS 7200RPM hot swap.
Same size drives, same speed, only difference is SAS>SATA.
Thanks
Thanks
