rampantandroid
- Jun 14, 2006
Found this nifty little program today... It's called "mControl". It lets you control DDC/CI settings from within windows.
Meaning... You can change the brightness of the monitor, see power usage, select preset color modes (standard, game, multimedia, etc) , custom RGB settings, and walk your dog... all from within windows. One of the biggest problems with this monitor is that there are (apparently) issues with 3D games causing the monitor to be locked at 100% brightness after you exit a game. I wonder if this program would fix that.
Regardless, it's a hell of a lot more convenient than messing around with Alienware's cryptic menu options... It's got a 21 day trial, works on almost every monitor, and made by the same people who made powerstrip. Can download it form the developers website: http://www.entechtaiwan.com/
My solution to the monitor being locked to full brightness - which happens when you enter a 3D game - was to just pull the DVI cable and plug it back in (power monitor, pull cable, plug in, power monitor) - voila, normal settings. That vision doesn't return brightness to normal on exiting is ANOTHER reason in a list of MANY to say nVidia's 3D solution is complete bullshit....that said, I'm curious to test this app to see what it can do with 3D - can it override 3D's nonsense?
Thanks for the info, and I'll try to test far cry tonight.
