rampantandroid
- Jun 14, 2006
So...seems like no one ever created a thread on this monitor...looks like some owners are out there though - just got mine from FedEx today and hooked it up before running to work - I have to say, I didn't miss TN panels.
Initial impressions, from just using Windows (no gaming, no real videos watched):
Vertical viewing angles are bad. Viewing it from above is worse than viewing it from below, oddly enough
Backlight bleed seems to be not too great - overall the blacks aren't so black, and the uniformity isn't good on the edges:
The AW2310:
http://rampantandroid.com/images/Alienware/AW2310 2.JPG
My old VX2025:
http://rampantandroid.com/images/Alienware/VX2025 1.JPG
Comparison between the two (VX2025 on the right, and is closer to the camera, hence why it looks bigger.)
http://rampantandroid.com/images/Alienware/comparison.JPG
Colors: well, I'm hoping someone here can help me. The base monitor settings are TOO bright and TOO washed out. It's just embarassing how bad it looks. Can someone give me the settings they use? Edit: FlatpanelsHD offers some settings that look like they might be good.
Banding/Dithering issues: What can I say other than "present"...they're there, not THAT bad looking - viewing photos I don't see it. On fades to/from black in videos I see it.
As for construction: as is par for the course with Dell, the stand is sturdy and well constructed...however, there's no pivot ability...no portrait mode for me, I guess?
Anyone else have thoughts on this monitor?
I'll add more photos in a bit.
Further thoughts:
Having used it for a few hours now: I have to say I like it - I've not gamed yet mind you, watched videos, looked at photos, browsed sites and so forth. All in all, the viewing angles look good - nothing unexpected for TN panels, and perhaps better than most TN panels, really.
Color wise, once I used Flat panels HD's settings, the colors look fine; what still looks off is the brightness - everything looks TOO bright and slightly washed out.
As for what I DON'T like: Hooking up cables is a royal pain; with no ability to go to portrait mode, I can't easily see the connections. This might be forgiveable is this were only the DVI/HDMI/Power connections, but this is ALSO the 4 port USB hub.
Furthermore, the USB connections are ALL on the bottom; unlike other Dell monitors, no USB plugs are on the side of the monitor.
The AW2310:
My old VX2025:
Further thoughts:
