Dell 3007 and VGA
About to pull the plug on a Dell 3007. My computer will handle the DVI Dual Link with no issues. My question is, I work on a lot of computers and most of them don't have DVI let alone Dual Link. Most of them have VGA. This will be my only monitor. Will it work with a DVI-D to VGA adapter? Then just run a VGA. I know I will not get full res. but as long as it is visible and able to work on I am all set. People that have or can try this first hand I would appreciate.
Thanks
Link to DVI-D to VGA Adapter
http://www.newegg.com/Product/Product.aspx?Item=N82E16812226023
Yes it will work. You will not be able to run the full resolution of 2560x1600. I am 99% sure you will be able to run 1920x1200, which is the next step down.
Are you 100% sure and have tried this first hand? Like I said don't care about the resolution just being able to see it and work a little.
Also the dongle that I listed above you be the one to work and I would go, Dongle on monitor to VGA cable to Computer?
Cheers!!! and thanks for the quick response!!
That just looks like a regular DVI-I to VGA adapter and therefor would not work. A VGA to DVI-D would require some electronics to convert the signal so would be much bigger. I don't think such a converter exists since the only people that would want it are people who 1) are rich enough to get 30", 2) yet are stuck with VGA, and 3) are happy with 1280x800 on their expensive 30".
It is DVI D to VGA. DVI I has four pins surrounding the long pin.
Maybe it has the connectors you want at each end, but I for one would be surprised if the cable works. But don't let us stop you...
I think you need something like Matrox DualHead2Go (even though you don't need the dual head functionality).
Yea these are the answers I was reading all over the net. Couldn't find a def yes or no. Wondering if anyone can or has tried it.
The following needs to be accounted for:
1) The 3007WFP would need to have a DVI-I port to handle a direct analog signal so a simple VGA to DVI converter is out, meaning you need an ADC unit (analog to digital converter) because the port is DVI-D (digital) only
2) The analog to digital converter would have to provide a proper single-link or dual-link DVI digital signal that the monitor would handle. This monitor has no real scalar so it only supports two resolutions: 1280x800 (single-link) or 2560x1600 in dual-link DVI mode.
What you need is a scalar/switcher that will handle 1280x800 or 2560x1600.
I know a company named Gefen makes them, I just don't know if they have any dual-link models. But, I think it's gonna cost you a fair bit o' $$$$ compared to a simple cable.
I would be pretty confident saying a simple cable is not going to do the job, though I'd like to be wrong for your pocket's sake
