dell 2950 perc6/i intergrated
lone wolf
I have a Dell 2950 with a perc6/i intergrated into it. It currently has 3 450gb SAS drives. I want to use this for a ESXi host but want to throw 3 2 tb hard drives in there. will this work with this raid card? I am trying to see if there is a limitation on the storage.
It should, but the volume will probably not be boot-able unless you make volumes smaller than 2TB. I'm using 6 2TB hitachi desktars with a perc 5/i on a 2950 in RAID5. I made one bootable volume at 100GB, and the remainder storage.
The drives are apparently "invalid" drives according to the Windows management software, but they still seem to work.
I would recommend updating drivers and firmware for the dell card and motherboard as well.
Also keep in mind drives of different spindle speeds should not be stacked on top of each other.
