Dell 2709W versus 3007WFP help needed
Le_Freak
Hello,
I hope you guy's can help me out with some questions and some considerations i have.
Well the thing is, since a couple of day's i have a dell 2709W but i don't know if i want to keep him because of some facts.
* bigger pixelpitch
* input lag
I still have a couple of day's to decide if i wanne keep this monitor or replace him with the Dell UltraSharp 3008wfp.
But before i fo that i like to know some things from you :)
First: can anybody tell me if i change the 2709 for the 3008wfp can i still play games ? for example i play call of duty WAW and that game has a max resolution of 1920x1200.
(I have a 8800 GTX 768mb)
Also i like to know if this monitor also have the input lag problem ?
And ofcourse i like to know if it's a better choice overall.
Hope you guy's can help me out because this situation is really bugging me :confused:
I have also an 2709w, but not really notice the inputlag, I should try a fast game as trackmania or something.
pixelpitch is big indeed, but because of it , it is also more relaxing to read from it, unless you are always sitting really close to it. the 3008wfp has an s-ips panel, so alot less input lag, but resolution is pretty high, and with lcd it is always better to play in the native resolution.
the 2709w has pretty good scaling , that I know.
both are great screens. and don't forget the 3008wfp is more expensive (well here in europe)
Neither is ideal. If you notice input lag on the 2709W you will likely notice it on the 3008WFP. The 3008WFP will give you better pixel pitch, but the input lag change will likely be difficult to notice because it is still fairly high, as it's only one frame (16ms) difference.
http://www.digitalversus.com/duels.php?ty=6&ma1=88&mo1=398&p1=3699&ma2=88&mo2=413&p2=3936&ph=12
For smaller pixel pitch and less input lag, the Planar PX2611W (25.5") or HP LP2475W (24") are both noticeable improvements in both areas.
WOW man i have returned my 2709W and i have now the 3008WFP what a difference, not only sharper, but also much better colours and better for gaming.
Can anybody tell me what the best settings are for gaming, or in general what i really must configure ?
