Dell 2405 or LCD-TV.....confused!
Blinky7
Hello all and happy new year to everyone!
I currently own a pretty good PC (athlon64 at 2.7GHz 300MHz DDR 2.5-4-4, 2 raptors raid-0, 6800GT, DFI SLI-D, 500W Fortron PSU etc...) but I don't posses that much time anymore nor I want to keep spending money on this expensive sport called overclocking. So I decided to sell my rig since in the lottle time I got to spend in my room I mostly want to do multimedia stuff and not gaming. So I basically got home theater needs and not so much PC needs. SoI decided to sell everything and build a small home theater in my room so I can relax in my bed and watch at movies and stuff with friends or alone whenever I got time. My PC configuration costs around 1800 euros....which is too much money wasted if you are not gaming.
So I decided to sell everything, and get an average sized LCD screen, 24"-32" so I can enjoy multimedia viewing. Then, if I need some gaming, I could always get an xbox360 for 300 euros which is dirt cheap and game....
But for the time being I am mostly worried about doing the best selection on the screen.
Right now I got a Dell 2005FPW on my system. 20" widescreen is nice for PC gaming, but not big enough when I sit on my bed to watch movies. The distance is approximately 2 - 2.5 meters and I need something bigger. Here is where I am really screwed up trying to make the best selection. 1 choice would be to return my monitor to Dell and ask them to replace it with the Dell 2405 (by paying the money difference of course). This would cost me 560 euros. If I sold my used 2005FPW I could get around 540 so the total cost of the 2405 for me would be 1100 euros.
1100 euros is A LOT for only 24", and other than that, the 2405 might also be a perfect PC display but I ain't gonna use it as such...Plus, by being primarily a PC display it doesn't have a built-in tuner so this would be an additional cost. At this cost I could approach 32" LCD-TVs and for much less I could get a 27" LCD-TV. The only thing tempting me with the Dell is the fact that it has the resolution required to support 1080p HD, and this is somewhat futureproof. Every LCD-TV I have checked at is capped at 720p natively. A bad thing about LCD-TVs is that I can't really know their pros and cons....I know some stuff about LCDs but the manufacturers very rarely state what type of panel they use (TN+film, S-IPS, SMVA,SPVA) so I can't understand much. I can only check the resolution and the inputs, but even models with the same resolution and inputs vary greatly in price so I don't know in which way the pricier ones are better. Then, the models are different for europe and the US in LCD-TVs and the confusion becomes even bigger when trying to find a review online....
Bah....what do you think I should do? Do you think for 2 - 2.5 meters distance 32" is overkill and I should go for a 27"? And can you suggest any spesific unit close to 1000 euros? Any good place to find information?
What is going to be your HD source? OTA or cable/sat? If it's cable/sat box then you will have your tuner built into the cable/sat box. I have my comcast HD box plugged into my 2405 w/ component cables. You will need a tuner if you go OTA. Personally.. since it's primarily for tv.. I would wait just a "little" longer for the 30" Dell or get an updated 24" w/ hdcp. (but time might be of the essence here) The resolution is going to be a lot better than most 30+ LCD tv's and you could always use it for pc use. (it also might be cheaper) Keep in mind that if you use the dell as a TV then you will not get any remote control functions (since there isn't any) but that may not be a big deal.
The dell 3007 is out of the question because it will surely cost A LOT! The 2405 is already kinda expensive for me.
I won't be using an HDTV tuner because there is no HD signal currently in my area (europe, Greece). I just want an HDTV because it is more futureproof, plus I will be able to play xbox360 or PS3 in good resolution if I ever get one of those.
The 2405 is only attractive if it can do 1080p for the future....other than that I am better off with a 32" LCD-TV 720p that will play TV for me, it will be huge and it will still have enough detail for the xbox360 for about the same money. The only thing holding me back is the fear of needing 1080p in the future, and the fact that I can't compare the TV sets online to be sure to get a good one for the money.
even though the panel itself with 1920x1200 support it may be possible to do 1080p.. I don't think the scaler in the 2405 will do it. According to the specs of the "genesis" scaler used in the 2405... 1080i is the maximum supported. Here is the document stating the specs of the genesis scaler used in the 2405. http://www.gnss.com/products/gm1601_ProdBrief_C1601-PBR-01.pdf I could be wrong though..
That's what I have heard, and it's a real shame :( because it's such a great monitor, plus it would be easier for me to get it by returning the 2005FPW and not losing money by selling it as used.
So I guess I should go with an LDC-TV, but I can't decide on the size....27" or 32"....and I have no idea how to judge the various candidates. I can only understand the resolution which they state and the inputs. But I can't know the panel they use......I really like S-IPS like the one on my 2005FPW, they got great colors, average contrast(worse than MVA/PVA but enough and better than TN+film) and enough speed (worse than TN+film but enough and much better than MVA/PVA). Plus I don't know about the resolution. Most sets have a 1366x768 resolution which sounds stupid since you will need to scale a bit for 720p material.....why are they not all 1280x720 to avoid scaling? so stupid....
And then I see all brands have a TV for 1200 euros and another one for 1800 at the same size....same resolution same inputs....what is the difference? Are they upping the price for design, speakers or other things like that which I wouldnt care about? or The cheap models got horrible scalers or something? I am so confused....can't decide.
2.5m viewing distance? Get a cheap 480p projector and throw up a 60" image directly on the wall. I don't know European PJ pricing, but you should be able to do it for substantially less than the 1000 euros you're contemplating.
speaking of projectors, I have found this Hitatchi PJ-TX100 which is under 1000 euros and is HD ready and has recieved some great reviews from customers saying it is almost as good as a 5k unit. But I am a real noob on projectors, and my room is kind of small....it's like 5x3 meters, so I don't think it's suitable. I would be watching from 2.5 meters distance but I would be on my bed....there is no place for the projector to stand on. Plus this one says it needs 2.8-4.6 meters to show....so it doesn't seem suitable. Another thing that turned me off is the bulb life of 2.000 hours....because with 5 hours average per day I'd need a new bulb almost every year...which means 210 euros extra per year.
2.5m ( 7ft) distance is not enough for home theater applications. Rearange furniture or move to another room. Or get a small bedroom tv. I would keep the computer if i were you. For Home Cinema the optimum screen and front speaker distance from viewer is 16ft - about 5 meters, or 3 to 4 times the screen size-diameter.
I think it all depends on the size.... If i got 2.5 meters then that's what I got...I can't change room....but I can adjust the TV size to fit... For example I know 20" is not enough for me....cause I have been watching stuff on the Dell 2005FPW and it is not big enough.
I think 27" would be ideal...what about you?
