Dell 2209WA @ 75HZ
MagicMan84
Configured the custom resolution.
Nvidia control panel and my Dell monitor menu both show 75hz.
However, all games displays a maximum setting of 60hz in the menu.
Anyone able to get fraps to show a vsynced cap of 75 fps in their games? :confused:
Edit:
I had to install the driver from the 2209WA CD. I'm using Vista x64, perhaps that had something to do with my problem. Before, the OSD would always revert back to 60hz when I opened a game. Now my games are reporting 75hz, so the problem is resolved. There was another guy who had the same exact problem as mine, hopefully he reads this thread.
Bump to anyone else with the same problem. Fixed.
Thanks for the info MagicMan84. There is also a way to lock in the refresh rate using RivaTuner or Powerstrip, but it's better that you found a way to do it via standard means.
