Krazy_Joe said:hey defyant, where did you get that retaining clip for the res that holds it in place (metal bracket?) on the HPRES II
Someone sticky this thread! This man is a WC'in mad scientist!![]()
Mysterae said:Nice work mate, you're an inspiration for us water-plexi lovers!
Regarding your custom reservoirs, the flat inserts in the tube res's, are they there to reduce turbulence, reduce air, or just for fun? I'm designing a res that's about 190mm tall, 50mm in diameter and I'm a bit mystified if air bubbles will be created and then sucked in through the pump.
By the way, you've set the bar!![]()
Nettwerk said:Damn fine machines sir...
btw: you selling any of those tube res's?
Defyant said:Cheers Mysterae, thy are mostly for showthe "inner tubes" help more with turbulance, you prolly only need to use the one inner tube, but i think it looks more balanced with 2.
You could "do away" with the inner tubes altogther and just run a "divider" that runs up the middle of the res to about half way.
I just dont think this looks as good as the inner tubes.
I'll take that chance, you do such great work that I'd still be proud of to use one.Defyant said:thanx Nettwerk. no matter how well i build a res, theres always the chance!!! that they can spring a leek,,,, if i stuff up on one of my own sys ! not such a big deal.
but if one went "kaput" in your sys mate, i'd hate myself forever,,,, you prolly would too
for that reason i try not to sell them![]()
