Defective DP cable?
vegeta535
So last night while gaming my monitor crapped out. Wasn't getting any picture to come up over display port. It has been acting up by randomly losing G-SYNC A quick input change would fix it tho. I tried different DP on my 1080ti and still nothing. Went to hook using a HDMI cable and picture came back. It stuck at 50hz and no G-SYNC of course. What's the chances that it is the cable and not the port on the monitor? I ordered a new cable but it won't be here til tomorrow. The monitor is a AOC AGON AG352UCG 35".
Could be the input on the monitor. Do you have another monitor with DisplayPort to test? AOC don't have a stellar reputation when it comes to quality.
I've had about 1 out of every 5 DP cables end up being bad. Most of the bad ones came in the same box as the monitor.
I just got home and not I'm am not getting a image on the HDMI port. I dug out a old HDMI monitor and the same thing. Looks like the video card out puts bit the dust. Windows is loaded and can hear sounds just no image.
Hmm after a couple reboots both DP and HDMI to the other monitor are working again x.x Guess it is the 1080ti having issues.
