Decisions decisions ...
InfernalMachine
All of the above; it's a general purpose machine.
Bang for the buck within an unlimited budget but just because I can spend it doesn't mean I want to.
3) Where do you live?
Austin TX - No microcenter :(
4) What exact parts do you need for that budget? CPU, RAM, case, etc. "Everything" is not a valid answer. Please list out all the parts you'll need.
I can go two routes:
Route A: CPU, MOBO
Route B: Full rebuild
Case: I'm torn between the Silverstone RV02 and FT02 but I'm more concerned about the internals at this point.
Corsair 1000W PSU
Dual ATI 512MB 4870s - they're like JET ENGINES and run like I feed them coal.
Corsair XMS DDR3 1600 9-9-9-24
Corsair Cooling Hydro Series H50
6) Will you be overclocking?
I'll be dabbling to see what I can get.
24" 1920x1080 (res I use) but would like to expand to 2-3 monitors.
Soon!
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? etc.
No need for Raid (have a NAS) or Firewire and don't NEED to have dual card solution; i'm totally fine with a single card solution.
10) Do you already have a legit and reusable/transferable OS key/license? If yes, what OS? 32bit or 64bit?
Win7U64
But first some history:
I was running and Intel Q4590, Intel skull trail x48, dual ati 4870s, 4GB DDR3, 1000w PSU. 'Something' in it died, I'm assuming the CPU and/or mobo (as I know the cards and ram work fine). Even if the PSU works I would want to replace it as it's loud and not modular (damn thing has been unruly in every case).
What I want is a QUIET PC (hence the corsair cooler and Silverstone cases) for a change without too much sacrifice in performance. I don't need e-peen framerates
I'm looking at two builds:
AM3 PhenomIIx6
Asus Crosshair IV or MS890FX
Sticking with my RAM+Video cards until a good price on a 5970 rolls along or a 6K refresh
or
i7920/930
Motherboard GA-X58A-UD3R
6GB Corsair Dominator
Nvidia dual GTX460s (or keep my 4870s)
I'm worried about moore's law ;) I'm essentially building a rig that is 2years old from release of the tech (i7) and with Bulldozer Sandy-Bridge coming I'd hate to date myself already.
I've my R1 m11x doing full duty right now as well so I am not 100% dead in the water but the little guy can only go so far.
What's the priority of this system? You could go a lot farther with a Core i7/X58-based system (however, reuse your Corsair RAM instead of buying the Dominators), but it will cost a bit more.
If decent gaming performance is a priority for you, the dual GTX 460s are a good idea regardless of which route you take (though that may be another good reason to go Socket 1366).
The new XFX PSUs are pretty good -- they're made by Seasonic -- and you can find several deals on the Black Edition 850W model.
Gaming and rar/ftp'ing, office, web apps, minor video and Photoshop work. Multitasking.
The issue with using ram with an i7 rig is I only have two sticks and this ram is discontinued so i would need to buy the renamed matched pair and ditch one stick for trial channel.
I believe that Danny Bui has the numbers, but the long story short is that a tri-channel RAM configuration doesn't offer a huge (read: noticeable) performance boost over a dual-channel setup. Having said that, however, I still believe that Dominator RAM is overpriced and/or overrated for all but the most serious overclockers.
IIRC, the AMD-based SLI boards aren't as good as those boards with AMD/ATI chipsets. If you're leaning heavily towards the dual GTX 460s, you should strongly consider the X58 system.
I believe that Danny Bui has the numbers, but the long story short is that a tri-channel RAM configuration doesn't offer a huge (read: noticeable) performance boost over a dual-channel setup. .
Correct. The difference is only 2% to 5% at best. Many X58 motherboard do support running dual channel RAM just fine.
