Are you referring to your stats page, where it says if you are active or not?
If this is the case, you will be "active" once you start turning in Work Units and they are reported on Stanfords Stats site.
I've seen that problem on the PS3.
Try uninstalling and reinstalling F@H.
Press Triangle while you're over the F@H icon to get to the uninstall menu.
http://userpages.umbc.edu/~willm1/setup-fold/
I would use this to setup F@H as a service, best way to run the program IMHO.
Use that after uninstalling the graphical version.
Posting pics of good looking women is always a good place to start!
Check to see if it is running
I used ctrl-alt-del, processes, and then look to see if F@H is running
Single core, it will show up as 100% CPU Usage, unless you changed this.
if you have a dual core box, 50% CPU Usage per core
You may need to restart your computer and then let it do its thing!
Dang Marty, I thought that was a link to pics of good looking women.![]()
