Deciding between x38 and x48 mobos
semisonic9
I've got a build coming up sometime next month, and I'm trying to decide on mobos.
Last I heard, there wasn't a lot of difference in the x38 and x48 chipsets? However, the x48 prices seem pretty reasonable at $180-220 or so on the lower end, up to $330 on the higher end. I'm considering the Gigabyte GA-X48-DS4and the Elitegroup ECS X48T-A atm, with my eyes open for other options.
Also, there's the chance that I won't need an xfire capable mobo, if the 4870 1gb will do everything I want it to until x-mas of next year. In that case, I'd love some recommendations on p45 mobos as well.
~S
Ditch that ECS, the X48 mobos from Asus, Gigabyte, MSI, DFI and Abit are all good choices. The P45 mobos from Asus, Gigabyte, Biostar and MSI are also good choices tho I'm leery of MSI's lower end P45 mobos
Asus P5Q-E - Best bang + features for your buck if you run a single graphic card. Very nice motherboard. If you run Crossfire, grab an X48 and enjoy. Only reason to buy an X38 at this point is if you can get it $20+ cheaper.
damnnn, i want that rampage extreme. u got any more pictures of it?
DDR2 vs. DDR3 on some boards is something to look for. Both X38 and X48 have both DDR2 and DDR3 variants.
Yeah. Since I can't really afford DDR3 yet, I'm going with DDR 2 boards that will run 1066 ram. I will OC the processor to the 3.4-3.8ghz range (depends on watercooling), and want room to OC the ram as well.
~S
What the board is rated for has no bearing due to the fact that you're OC'ing, so don't worry of a board is only rated for PC6400, as long as you know that mobo OC's well it'll be fine.
The X48 Gigabyte boards have a DPC latency issue (not all boards have it but many do...the P35 ones as well). They seem to have the issue fixed with the P45 boards but right now i would stay away from the X48 Gigabytes
So whats coming after the x48 chipset ? It seems that intel is pumping out new chipsets like theres no tomorrow .
I thought this was the last round of LGA775 chipsets personally, but I've been wrong before ;).
Ya, Pretty sure last 775 mobos.
Just go X38. Many Asus boards support 1600FSB anyway.
No reason for X48 unless it's the same price as the X38. I love my DFI board.
