Decent PC Upgrade - Got any suggestions?
ps3guru03
-------UPDATED MAY 12, 2007-------
Alright. Officially made my last decision. 7900GT KO and an extra 2GB of Ram it is! Total cost to upgrade was 170.00 bucks....whoo hoo!
Thanks for your help/input guys! :) Helped me a lot!
...............now to upgrade my CPU..lol....(Pentium D 820) ...
First of all, you do know that you need a 64bit OS in order to use all 4GB of RAM?
Second, if you look around the For Sale, For Trade forum here, you can get a decent card for cheap here. I've seen the 7900GS (A better card than the 7800GTX if I'm not mistaken) here on the fourms for around $100 to $120 with shipping.
Third, what are you planning to do that requires this upgrade?
Are you sure? I really need a 64-bit OS? I contacted dell and they told me the max memory my mobo can support is 4GB. They didn't state anything about the 64-bit OS....
For the GPU I did my research and found that this card can be better, way better than a 7900GS and maybe a GT after being overclocked....
Planing to update because I will be doing a bit more gaming and I am going to do a lot of work with video, pics and music so that 4GB will I think help a lot.....
If you got any other suggestions, please feel free to post them...
Physically able to support 4gb? Yes
Able to address all of it? No.
Even with a 64-bit OS, there will still be a chunk missing for PCI address space. Usually around 256mb, but, it depends on the board. Having a 64-bit OS doesn't change this
Given your hardware configuration, 2gb should be enough to prevent memory being the bottleneck.
Take the $80 you'd save and buy a faster hard drive.
What Vertigo Acid said :)
However, I say use that extra $80 for a better video card like this card:
SAPPHIRE 100176L Radeon X1950PRO 256MB PCI-Express - $146
Oh and get this set of 2GB RAM:
G.SKILL F2-6400CL5D-2GBNQ 2 x 1GB 240-Pin DDR2 800 RAM - $95
Thx....Hmm...I'm on a really tight budget, and I want to save that extra 80 for a bigger/faster HD....also...my mobo cannot support DDR2 800 Ram....only 400mhz and 533mhz...ya, I know it sucks..
Well, after the suggestions, I decided to go by keeping my 2x512mb samsung memory and taking out the other stick and adding 2x1GB samsung modules that will be bought here on the [H]...:D...which makes it a total of 3GB of Ram...(1GB for the video card, and the other 2GB for the PC...:)) I will also be sticking with my choice of a 7800GTX KO ACS3 edition GPU...
Cost to upgrade now...
- Samsung DDR2 PC4200 Memory 2GB (2x1GB) 80.00
- eVGA 7800GTX KO ACS3 edition 100.00
- Ultra 600Watt PSU Free
180.00 Total....with shipping it's 194.00 ;)
Again, if you have more suggestions please post them.....
Yes it does. With Windows XP Professional x64 Edition and 5GB of ram I had all 5GB of ram available to Windows.
Are you serious...I have Windows XP Professional x64 edtion too...so I guess adding 4GB will work, and windows will be able to read all of it....can anyone else confirm this before I go back upto the 4GB option?
I am serious. My old Opteron setup had 5GB of ram and it worked fine in Windows XP Professional x64 Edition. With the 32bit version of XP I only got 2.5GB.
Alright...that's good news...so I guess I can go back to my 4GB option...well maybe...I gotta think about what I'm going to get...
In the meanwhile, please post any other suggestions...thx!
If you're really trying to stay within budget, then I would agree with Veritgo Acid and suggest that you only stick with 2GB of RAM for now. (You could always add more in the future, should you decide later on that you really need more RAM.) Personally, I'd use the "savings" and get a larger hard drive (you can find many drives up to 320GB on sale for under $100).
Additionally, keep in mind that unless you're talking about "instant" rebates, you still have to spend a lot of money up front. Plus, most rebates have some sort of "catch" (e.g., "limit one per customer" or "rebate of up to $50"), so that $260 "after rebate" could easily jump to $400-$500+ "before S&H." If you're really strapped for cash, check out the FS/FT Forum here.
And dude, you got a Dell? Check the online support site to be sure that the PSU you're choosing is compatible with your system. Dell has used proprietary motherboards and PSUs in the past... I don't think that's the case now, but it's always good to check first.
That's going to depend on whether the memory controller/CPU in question supports the ability to remap the address space or not using PAE, which isn't dependent on whether the OS is 64-bit or not.
I was under the impression that only Xeons of that era had this feature, but, a quick googling shows that the Pentium D CPUs do, and so as long as the motherboard also supports this, 4gb usable should be possible.
OP: It's still not a good investment at this point
You do know that RAM can downclock right? So if you get DDR2 800 RAM, you can use it on a mobo even it's max speed is DDR2 667. Anyway, that RAM kit you chose has a good price.
Oh and where are you getting the 7800GTX for $100? As for that power supply, check out this review and see if it's the power supply you truly want:
http://jonnyguru.com/review_details.php?id=34
Wow.......Thanks again for your suggestions people! :)
Well after reading, and doing a little research, and find that I will go with 3GB of RAM.
I currently have 3x512mb samsung sticks in my PC right now which totals 1.5gb of ram. I will be taking out one with will be a total of 2x512mb samsung sticks and replacing them with 2x1gb samsung sticks which will be 3gb of total memory. Checked and found that windows will be able to read all 3gbs of memory.
Also, my PSU will be able to support my mobo, so I guess my PSU choice is fine...
Also, I will be going with the eVGA 7800GTX KO ACS3 edition GPU. I am buying it from a user on another forum.
Here's how much everything will cost....
- 2x1gb Samsung DDR2 PC4200 RAM 80.00
Total comes down to 180.00, and 194 with shipping....
Again, please post any other suggestions you may have...before I make my final choice...thx!
My question to you then, which pin is power ON on that powersupply? 5 or 16... And also 7800 GTX is really old card, get 8800 GTS 320.
The guy has a very limited budget so the 7800GTX for a $100 is a good price. Anyway OP, I think you should hold off on the RAM upgrade and spend the extra money on a better video card like the Sapphire x1950Pro for $146. Or buy a faster hard drive like the Seagate 7200.10 320GB SATA hard drive for $80.
1.5GB of RAM is sufficient for many games out there. Are you sure that you need 3GB of RAM? Or the better question is, will 3GB of RAM actually be a big help with whatever you're doing with this PC now? Is 1.5GB of RAM not enough for you?
I've seen the memory remapping feature on boards going as far back as the A8N-SLI Deluxe.
Wow...I didn't know that...but I decided to stick with 3GB of Ram instead of 4GB.........
Yea. 100.00 for a 7800GTX can't be beaten...please note that this is also the KO ACS3 edition. Not the average 7800GTX. I really am looking to buy the 7800GTX instead of a better one. Plus to me, it's going to be like I got a 8800 Ultra or something becuase I currently have Radeon x300 in my PC.... :D
About the HD, I am going to purchase a bigger and faster HD with the 80 bucks I save for not going with 4GB of Ram. Lol, the funny thing is that I wanted to get the same exact harddrive you have stated. I posted a WTB thread, so please take a look if anyone one has one for me to offer. So far I had one offer which was a Seagate 7200RPM 16MB 320GB SATA HD for 75 shipped. Is that a good price, because some sold here for 50-60 bucks?
Also, I am now going to be working a lot with audio and video rather than gaming so that GPU and 3GB of Ram can help a lot. Here's how I divided my memory up....2GB for the PC, and 1GB for the GPU.
Total cost is still at 194.00 bucks unless I get a HD. LMK if you have any other suggestions, or if you see a hot deal on a HD. ;)
Thx in Advance!
My final decision is listed on the first post. Please read, then LMK if you have any other suggestions. Thanks Again!
