[2dP]MightyMatt
- Feb 3, 2007
I've been trying to spend more and more time reading about water cooling and catching up for my lack of knowledge on the subject. I'm thinking about putting together a water-cooled system when I get my E6600 or E6420 in Q2, this year. I've been hearing a lot about when making a radiator/fan rig that you want space between the radiator and fan to get rid a the "dead spot" in the airflow, from where the fans aren't moving in the middle. If this is true and unless I'm misunderstanding this issue, then why doesn't this Swiftech setup look like it's capitalizing on fixing that issue? This picture/product makes it look like there is no such thing as a dead spot, or maybe they just don't think it affects their product and it's performance that much? EDIT: I just read about a shroud. Is that little amount of space between the radiator and fan enough to get rid of a dead spot?
[URL="http://www.swiftnets.com/store/product_details.asp?ProdID=313"]
[/URL]
I really like the things I'm reading about Swiftech, good quality and a great price. I am just curious about this setup and it's performance. Would you setup up this Radbox, radiator, and fan any differently?
Another thought, idea, and an issue I'm having is that I still have no idea if it's worth it to mod my case and put fans and a radiator(s) inside, or if I should forget about modding and stick fans and a radiator(s) somewhere outside my case, like in this diagram I whipped up.
Someone on the internet (maybe these forums) did this and I tried to mimic his idea in the drawing, it's all the normal components of a water-cooling system inside the PC case (blocks, some tubing, maybe a reservoir, and a pump) with a set of radiators and mounted fans grouped together on a stand to maximize airflow and cut down on any potential modding. The only issue with this idea (hope it's obvious) is the dust that would easily be collected on this panel of fans and radiators. Any thoughts on this? Does anyone have a picture of a comp with this idea in action or where to buy a stand that could fulfill this little dream of mine???
