I went to turn on my PC last night and it was stuck on the memory count. I have a SAPPHIRE PI-AM2RS780G with the LED diagnostic code. It was stuck at 50 (which I believe is initializing the USB). I disconnected everything and it went through the startup but then I a blue screen before Windows started. Its been fine for months with no issues; I had to go so I just left it.
I came back later and turned it on and it booted fine. I installed a new video driver and when the PC rebooted, it because stuck again. This time the LED code was 52. I cleared the BIOS and was able to enter the setup. Odd thing was that the text was messed up. Everywhere that there was supposed to be a blank spot, there was a zero.
I disconnected everything and took out my GTX275 and put in an ATI X300 video card and it still gave me the same code. I took everything appart, reseated the memory and reconnected everything. When I start up, it gets stuck at LED code 75 or 7F. It alternates. One of those codes has to do with initializing the PATA/SATA system but it does it with no SATA drives connected (I just have one sata hd and one sata dvdrw on the PC).
So, is it dead Jim?
So, is it dead Jim?
