dead abit ic7-g?
Gk22CoE
So all the sudden my computer crashes wial playing a game and will not boot back up. I try to clear the cmos and when trying to start the computer back... nothing at all happends when I hit the power button.
the power button cable to motherboard is fine
I tested powersupply and it's fine
I tested a new cpu and still no start up
I change the cmos battery and still no start up
now i'm stuck and dont know where to go next. any ideas? thankx
does it boot outside the case?
i've had nasty experiences with abit mobos and their tendency to pretend like they're shorting
not sure what you mean...
btw the green led on the motherboard is on when the powersupply is hooked up
not sure if this means anything but I just plug the power cable back to the mother board and the power supply turn on for a instant.
Take the mobo outside the case, plug in the RAM, CPU, HS/F, and psu and try booting it outside the case. Remember to put the mobo on something that isn't metal..and I'd try to keep it off the bare floor as well. I usually put it on the anti static bag that comes with the mobo. I've had many experiences with abit mobos where I thought it was dead, but I could still boot it outside the case...so I don't know..try it?
now that I think about it this all happend when I was trying to clear cmos.
My question is.... Could the bios chip be bad? Would a simple bios replacement chip fix it?
please explain how you cleared the BIOS. Did you change the jumper to clear it and then set it back to its original position? Or what did you do?
yes, changed the jumper to 1&2 waited then moved back to 2&3 position
Don't you have to power the computer on with the jumpers in the clear position?
nope, it's normally recommended that even the power supply is unplugged
at least with this mobo, just swapping positions is enough, no need to power anything on
