DDR2 and DDR3
slugger_2003
Is there a mobo that supports ddr2 and ddr3? I don't upgrade my PC often, if at all and it would be handy if there was a mobo that supported both types of memory so that I can shift to DDR3 when the prices fall and become worth changing to.
I plan to use either the 8800gtx or 9800gtx (whatever it ends up being called), 4 gb of ram (2 * 2gb sticks) and a q6600.
Thanks.
If your going to buy something that supports DDR3 now you might as well think to yourself gee, when something that comes out finally really takes advantage of DDR3 do I really want it on this old chipset. Not to mention DDR3 is priced kinda retarded right now.
I was looking into this kind of board, think Asus, Gigabyte, and Foxconn all have one with this feature. The Foxconn is a little pricey, and the other two didn't exactly have an outstanding summary of reviews and thoughts on newegg.
No point. Current chipsets don't even need the performance offered by DDR3 RAM. DDR2 RAM is all that current chipsets need. So basically DDR3 RAM, even when it becomes cheap and extremely fast, still wouldn't be worth it since you'll have a CPU and chipset that doesn't need or require DDR3 RAM.
And by the time that DDR3 prices drop down, there will already be newer CPUs and chipsets that will actually require the extra performance offered by DDR3 RAM.
Although cheap mobos supporting DDR2+DDR3 simultaneouly are present, I still agree with Danny Bui that they aren't worth it at all, especially since you won't be able to install more than two RAM sticks on them.
