DDR4 isnt needed yet for high performance people go quad channel..
Samsungs are ~$45 for 2x4gb.
The true high-end DDR3 chips are the 1.5v 2000+ mhz Corsair Dominator 8gb sticks.
and the hipsters gloat about their discontinued triple channel.
does having triple channel mean i'm a hipster? if so, i feel cool now
Triple Channel bros!does having triple channel mean i'm a hipster? if so, i feel cool now
If memory speed doesnt make much difference, then..... what is the difference?
When DDR4 comes out, how much of a difference will there really be?
when is ddr4 coming out? im looking at replacing my 32gig set with a much faster 16gig set.
(socket 2011)
is haswell still ddr3?
what i have found is ddr 4 will be mainstream in skylake and thats set to come out 2015?
In theory, it'll double memory bandwidth over DDR3. The biggest determining factor for performance differences is going to be how future CPU memory controllers use the available bandwidth.
Latency is a big difference as well with higher frequencies (lower access times).
Re: person wanting to go from 32gb to 16gb of "faster" RAM, don't bother... you're looking at, in the VERY few situations it makes a difference, a couple of percent (literally) difference in performance from 1333mhz----->2133mhz speed. You're doing a downgrade by reducing your capacity there.
Exactly why I bought the much cheaper 1333 RAM instead of 1600+ back when there was a sizeable price difference. I knew I wouldn't be able tell a difference with anything.
But what about having the EPEEN of 2133?!
Thats why I bought the 1600 also because I didnt want to pay double the price for a few % if that in benchmarks. I love the samsung low profile ram!
LOL..... .
As far as the Samsung ram, if yours is the 1.35v 30nm stuff it actually very likely can OC flawlessly to 2133 with a moderate voltage bump. Not that it's really worth the effort, but if you want to flex that sig rig.... .
I would just keep what you have now. Besides benchmarks you won't see any difference in switching out your set as long as their clocked 1600MHz or higher. Even going from 1333Mhz to 1600Mhz there is a negligible difference in performance.
The money you intend to spend downgrading your memory would be much better invested in an SSD or something else where you'd see an actual performance increase.
Hmm. Likely won't see mainstream DDR4 til 2015 eh? And here I was hoping we'd see it early 2014 -- I was planning to wait on a new build until it was out but I'm not sure if my current rig will last that long without getting long in the tooth. Another year, sure, another two and a half? Hm.
Haswell-E is pretty much all but confirmed to come with DDR4. DDR4 on Broadwell is uncertain but unlikely. Skylake is almost definitely DDR4.
On AMD's side, it might be Excavator, or whatever the successor for the AM3+ socket is.
Sandy-E is basically a Xeon. So Haswell-E being DDR4 would mean Xeons getting DDR4 before desktops. That seems like it will cost an arm and a leg.
I'm quite new to this ram thing, but why do we need fast memory? the point is to get enough but what performence you get form fast ram?
Thats what I am wondering also. Will DDR4 start at 2133, and if so how would that compare to DDR3 @ 2133?(not to mention price difference)Massive RTS games seem to benefit from faster RAM, just check out one of our member's testing. But other than that, faster RAM really has limited benefits.
