- Apr 25, 2001
I wonder if they could keep up with brilong, Grandpa, and DooKey at the same time hammering for CPU work. hmmmm....![]()
I'm the small fry of that group, but there's no way they could keep up with all 3 of us.
FWIW, I don't think it's just you - just walked in the door and checked my Stats (yes, those are my priorities!), and I'm getting the same issue... Yes, others are getting URL's, so I don't know why we're having issues, but you're not alone!
EDIT: It also appears that the website http://www.majestic12.co.uk/ is down - I currently can't access it to post to their forums...
I can view the forums and site, there's nothing on the forums about an outage or anything. Hmm. what DNS servers are you using? Might be worth changing to Google or OpenDNS just to see if it helps, also can you ping the site?
HardOCP DC Vault Summary Updatedand getting a bit more automated...
https://dl.dropboxusercontent.com/u/123993183/HardOCP-dcvault-summary.htm
Nice work. I think this will be really handy.
Remove
ABC
RNA
LHC
The Lattice Project
PSP
Add
Constellation - Physical Sciences
PrimaBoinca – Mathematics
DistrRTgen – Miscellaneous
Numberfields – Mathematics
Distributed Data Mining - Miscellaneous.
OGR-28 – Maths
NRG@Home
MindModeling – Bio
WUProp - Miscellaneous.
On The Fence
Climate@Home
Okay guys, just a heads up - I'm taking everything off line for a few days. Came home to a dead AC today on a 106* California day, and that kind of heat will kill my rigs... My upstairs was 89* at 5pm, and my q6600 was running between 76* & 82*C under full load! I didn't even realize those 65nm core2quads could go that high!
Anyways, as soon as Amazon gets me that $25 part, I'll be back in the fray... Could be as soon as Wednesday evening, could be next Monday!
We're going to let the current galaxies run out - then do an upgrade of the BOINC software next week.
So once the queue is empty no more work units for a week.
____________
Regards
Kevin
International Centre for Radio Astronomy Research
I've suspended the user for 2 weeks. I'm working in the UK at the moment. I'll have a look when I get back
____________
Regards
Kevin
Where in Cali do you live? Here in Visalia it's been 100+ for about a week.Okay guys, just a heads up - I'm taking everything off line for a few days. Came home to a dead AC today on a 106* California day, and that kind of heat will kill my rigs... My upstairs was 89* at 5pm, and my q6600 was running between 76* & 82*C under full load! I didn't even realize those 65nm core2quads could go that high!
Just a bit north, in the Stockton /Modesto area. My wife's oldest sister lives in Hanford, and I've been down to the April Renaissance Faire over at Plaza Park next to the airport at 99 and 198...Where in Cali do you live? Here in Visalia it's been 100+ for about a week.
Hmm. Maybe try a traceroute to the site, see where it's dropping? Try it via IP as well, 212.74.44.131
Any other [H] members on the same ISP who could give it a try?
Sounds like they're blocking it then, yeah...is it in their policy to block sites at their discretion, or what? I would've expected at least some kind of notification.
Here is the current suggested changes to the Vault, I
____________
Regards
Kevin
http://pogs.theskynet.org/pogs/forum_thread.php?id=454#3173
Hopefully this will be the optimized client and potentially the first GPU app. So, if anyone is trying to push out position there, you may want to raise you cache to get more work. Otherwise, it may be better to focus elsewhere since the optimized app would perform a lot better.Granted this was posted on the 9th, I am hopeful that it will happen soon.
We do not get double Vault points. The points we get from running SOB work from the PrimeGrid client only gives us Vault points for PrimeGrid. Those work units do not get reported a second time from the stats export that SOB sends out. Therefore only work units ran using the SOB client will get us Vault points under the SOB banner.
