hardwarephreak said:Edit: Here is a snipet from Anandtech's article:
The Pentium-D and Pressler are examples of how not to do it: just slap two CPUs on the same die and call it a day. High clocked single cores like the upcoming Athlon 64 FX-57 will eat these massive chips for lunch in almost all benchmarks while consuming less energy. With the exception of some special far-fetched benchmarks, it will be pretty hard to justify the reason behind these dual cores.
Luckily, Intel's Yonah and AMD's Dual Athlon 64 cores show that better multi-core CPUs are on the way. At that point in time, we are entering the multi-core engine for real. And we can only applaud that because it unleashes a massive amount of CPU power upon the developers.
http://www.anandtech.com/cpuchipsets/showdoc.aspx?i=2377&p=5
Go ahead and tell me Anandtech is a division of AMD's marketing dept.![]()
You left out one Part.
Date: March 14th, 2005
Topic: CPU & Chipset
Manufacturer: Various
Author: Johan De Gelas
Things have changed since then. It was Anand's own review that blew that arguement out the water. The Dual Core 3.2 Pentium can't do single threads faster than an A64-FX57, but would kick the crap out of it multi-tasking and running most multi-threaded apps. That's how it's been for Dualies since the Dual Pentium Pros that I can remember, hehehehe!
Anand's Part 2 of their Dual Core review showed a $240 2.8GHz Intel DC. There's no further need for speculation
Sure I'll say Anandtech is BIASed for AMD but clearly not as much as some others. Wes Fink, one of their writers, is nothing more than an AMD-tool but that's for another thread.
No matter what's said here, the most important performance factor will always be Software support=P No matter if it's Dual Core or Dual Processor, software will determine who runs what faster.
Donnie27
