I have an old laptop which I decided to sell, so i'm now in the process of saving all data in it to my main storage machine. Of course I could have done it in many different ways, but I decided to network my laptop with my main machine using wifi. I enabled sharing for my laptop data drive so that I can map it in my machine and copy the data over. All is fine except that i'm not able to find a logical reason for the super low transfer speed. It fluctuates between 1.5 MB/s and 700 KB/s. In some few instances, it reached 5 KB/s . It is okay but why this speed?
WiFi limit can't be less than 54 Mbps = 6 MB/s
The slowest drive which will be my laptop drive is at worst SATA II drive(7200 RPM) so this shouldn't factor in...
The interface is either sata 1 or 2 so this shouldn't factor in also.
Only one more machine is wirelessly hooked to my WiFi router to access the internet.
Does the way the files/folders are organized play a role on this? I mean: For example, how much different will it to copy one large file of 20 GB size vs copying 10,000 files inside 500 folders with a total size of 20 GB ?
Edit: The laptop is placed 2 meters from the wireless router.
Thanks.
Thanks.
