I have a 2tb hard drive that just went bad. The partition basically disappeared. It is still running, but I can't get to the data on the drive. I have tried running a couple different diagnostic tools such as DiskGenius, DiskDigger, and RAW Copy from Hirens BootCD, but I haven't had any success getting at the files on the drive. Also, chkdsk doesn't seem to work because it can't detect the partition. I just want to recover the raw files on the drive. Is there a software program you would recommend for recovering data files from a drive?
Also, is there a program I can use to make an exact copy of the drive onto another drive so I can work on that one in case my original drive goes bad? I tried using RAW Copy but Im not sure if that worked.
Thank you very much.
EDIT: I just remember that before the drive got corrupted, I was getting a "Cyclic Redundancy Check" error message. Could this be a clue to what happened?
