darthmatin
- May 27, 2016
is it possible to place this chassis in horizontal position?
That is great to know that there will be triple fan gpu options available for this case. The 303mm limit, I assume that is including the bracket, and that most manufacturers include the bracket length in the specs, but this is not always the case?Here is a compatibility list for the GTX 1080:
Nvidia GTX 1080 Founders Edition = compatible
Asus ROG Strix GTX 1080 OC = compatible
Asus ROG Strix GTX 1080 = compatible
Colorful iGame GTX 1080 X-Top = no data
EVGA GTX 1080 SC ACX 3.0 = compatible
EVGA GTX 1080 Classified = no data
EVGA GTX 1080 FTW = no data
EVGA GTX 1080 Hybrid = no data
EVGA GTX 1080 KINGPIN = no data
Inno3D GTX 1080 iChill X3 = incompatible
Inno3D GTX 1080 iChill X4 = incompatible
Inno3D GTX 1080 iChill Black Edition = incompatible
Gainward GTX 1080 Phoenix = high chance
Gainward GTX 1080 Phoenix GS = high chance
Gainward GTX 1080 Phoenix GLH = high chance
Gigabyte GTX 1080 G1 Gaming = high chance
Gigabyte GTX 1080 Xtreme Gaming = no data
KFA² GTX 1080 EX OC Edition = compatible
MSI GeForce GTX 1080 Gaming X = compatible
MSI GTX 1080 Sea Hawk = incompatible
MSI GTX 1080 Armor OC = compatible
MSI GTX 1080 Armor = compatible
MSI GTX 1080 Aero = compatible
MSI GTX 1080 Aero OC = compatible
Palit GTX 1080 GameRock = incompatible
Palit GTX 1080 JetStream = incompatible
Palit GTX 1080 Super JetStream = incompatible
Zotac GTX 1080 AMP! = no data
[Zotac GTX 1080 AMP! Extreme = incompatible
Why does the Asus Strix 1080 fit with a length of 298mm? Yes on my site I wrote 295mm but this value is with a bit of clearance! The maximum length is 303mm![]()
You would be seriously impeding airflow to either the gpu or cpu depending which side you lay it on I think
Not to mention the PSU on the CPU side…
Now, if you had it flopped over on its side, with a cutout matching the air opening on the desk/shelf it was resting on; or attached feet to the blocked side…?
The EVGA GTX 1080 FTW's dimensions are: Height: 5.94in - 150.88mm Length: 10.5in - 266.7mmHere is a compatibility list for the GTX 1080:
did none of you look at page one? both sides are perforated. if you look at the pics you can see that the corners of the frame are rather beefy and it should be no problem to stick on some feet. screws would need to move inwards in the panel and could weaken it, possibly bend under the weight but it might work. so i'd stick/glue/epoxy some feet as close to the outside corners as possible.
edit: added top quote as I accidentally liked his q...
edit two: like so:
Oops sorry dude I misunderstood what you were meaning.I fully realize both sides are perforated, which is why I gave two work-arounds towards same; did you not read my post before quoting it…? ;^p
The connectors are on the top of the Asus card, therefore it fits. If they were on the side like on the Fury Nano, you have to add like 3cm so the card wouldn't fit.
With the 1500 cap I think the Kickstarter would be "over" (most sold out) after 48h.
Uhh, this is a custom case that is not in mass production. This should have been obvious and anyone here should know the basics of manufacturing a custom product. It will cost the consumer much more, as with any niche product of this caliber.I like this case. But the price is too damn steep even with the custom pcie cable. Ncase did almost the same amount of MOQ as you at a lower price for their indiegogo iirc. Nonetheless, I will wish you luck in your campaign.
I haven't received anything yet.Was an email sent out to those who signed up for the subscription on Dan's website?
Ncase was $205 during the first run. Taking into account the additional cost of the PCI-e riser, it doesn't seem unreasonable.Ncase isnt mass produced too during the campaign.
It was $205 on indiegogo. Now it is $185. It definitely falls within the price range that Lian-Li asked for. We've had this conversation already in the thread. If you don't see the case, features and quality justify the price then the case is not for you. If you can appreciate that the price is on par with other custom cases then go ahead and stick around.Ncase isnt mass produced too during the campaign and I do know this is also a boutique case.
I have not yet seen one - and I just checked my junk mail basket.
I'm amazed by all the people who think 1500 cases are going to sell that quickly to cause problems. There were only 907 backers during the M1 Indiegogo, for a run of something like 600 cases (according to TechReport). It took about a week for those to be sold. This case is even more of a niche than those were. (And the Cerberus couldn't even get the 600 it needed to get funded - I don't think this will have the same problem, but it's an idea of how tiny these markets are).
Yes, there's a lot of us here who are excited about this, but we're a small group of enthusiasts. I suspect we'll all have plenty of time to get orders in (though of course I hope it's wildly successful because it DOES fit a niche few others are filling).
This is also on my mind, if only someone could do a 3d render to give us an idea of how much the fans will be covered, but that is probably asking much. I think in this case a vertical fin arrangement seen in the evga and asus may have a slight advantage over msi's horizontal fins due to the air holes in the bottom and top of the case that are in close proximity to the gpu.Is it correct that the Asus card will have inefficient cooling compared to the MSI and EVGA designs inside the A4 because the outer fans are partly covered by the side panels?
We will provide 4 reward tiers:
- 1x A4-SFX Black (950 units)
- 1x A4-SFX Black (350 units)
- 1x A4-SFX Black and Silver (100 units)
- 2x A4-SFX Black (50 units)
- 2x A4-SFX Silver (50 units
