Daisy chain ARGB
Eviljoker
How many 120mm Argb fans can I daisy chain ? Currently have 6 silverstone ARGB 120mm. (Pf120 AIO controller) .Thinking about getting 2 120mm slim for push/pull config.. o and no 5v header. Only 12v header ,All will be running off a controller/hub...
I'm sure there's an upper limit, and if it's documented anywhere, it will be in your aRGB controller's spec sheet.
You'll know when it stops working... in my setup it's something like 8 before it starts dropping out. I need to get a powered hub soon myself.
