I think I have narrowed down the problem but would like the [H]ords take on my problem. My home network will not reach anywhere close to 100mbps on data transfer over the network; the max I can get is around 35mbps. The only thing I can think that it is is that the D-link (DI-604) router that is being used as a DHCP server, Router, and Switch can not actually handle 100mbps even though it is rated for it. I know it isn't the cable because after creating a crossover connection with the cable I can reach a speed much closer to the 100mbps speed. Now I know that no matter what you do you will never hit the full 100mbps, but 35mbps is pitiful. So here is where I am at, what can I do to fix this, if anyone needs any more information on my network setup please feel free to ask.
Any help would be appreciated,
Thanks,
Conundrum
Thanks,
Conundrum
