Cut or not?
AndyMac
Heres what I am working with.
and the fan
http://www.newegg.com/Product/Product.asp?Item=N82E16811998107
What my question is, how visible will the red color be thru the this...and if its not that visible, should i just cut it out?
Thanks in advance,
Cut it, I wouldn't worry about how much light will go thru it, I will worry about the air going thru it, and the amount of air will be very litle, and will also be very noisy.
