stelsevo
- Apr 17, 2014
case SX mid
case SX mid6.8L PHOTO ALBUM
This case is small in size, designed for maximum compatibility of components. You can not worry about overheating the components inside. It is recommended for assembling beginners.
Specs:
- Volume: 6.77L (305mm x 120mm x 185mm)
- Material: Steel frame (1mm), aluminum covers (1.5mm), Powder Coating
- GPU: length <278mm, height <140mm, width <44mm
- CPU Cooler: up to 48mm (CRYORIG C7 recommended)
- FANs: 1x92x25mm
- RAM: up to 55 mm
- PSU: SFX / SFX-L
- PCIe riser: LiHeat 300mm D.type (Complete with body)
- Storage: 2 x SSD 2.5" (Installation instead of a body fan)
Additional fastening of hard disks (Not included in the basic construction) allows you to install
1хSSD/HDD 2.5" 7mm
1хHDD 3.5" or
2хSSD/HDD 2.5" 7mm
With the installed hardware, the allowable size of the video card
GPU: length <177mm, height <140mm, width <42mm(GIGABYTE GTX 1080 Mini compatible)
- FANs: 1x92x25mm
- RAM: up to 55 mm
- PSU: SFX / SFX-L
1хSSD/HDD 2.5" 7mm
1хHDD 3.5" or
2хSSD/HDD 2.5" 7mm
case SLM itx
Travel light with a gaming PC assembled in our SLIM case! Play with your friends in the living room in front of a huge 4K TV! Replace your huge PC case.
Do not be like everyone else ... STAND UP ...
Do you want to travel with your home gaming system in your pocket? Then this case is for you! Do not wait for tomorrow ... Order today!
case SLM1 itx 3.7L PHOTO ALBUM
Super rigid design of light aluminum ... Easy installation of components ... External power supply ... This is a small part of the advantages of our case SLIM.
Specs:
- Volume: 3.7L (330mm x 185mm x 60mm)
- The CPU faces up and the GPU faces up
- GPU: length <185mm, height <135mm (Giga 1080 Mini compatible)
- CPU Cooler: up to 38mm (Noctua NH-L9i)
- RAM: up to 43 mm
- SSD/HDD: 2 x 2.5" 5-9mm
- Storage: M.2 only
- PSU: G-Unique 400W
- PCIe riser: LiHeat 350mm B.type
- RAM: up to 43 mm
- Storage: M.2 only
case SLM2 itx 7.5L PHOTO ALBUM
This small body can accommodate a full-fledged reference video card, an internal PSU SFX power supply. Ideal for a living room. When assembling, it can be difficult to lay cables.
Specs:
- Volume: 7.5L (323mm x 305mm x 76mm)
- GPU: length <298mm, height <130mm < 42mm
- CPU Cooler: up to 58mm
- RAM: up to 60 mm
- Storage: M.2 and options below
1) HDD: 1 x 3.5" (it is possible to install the button in front and USB ports)
2) HDD: 1 x 3.5" and 2 x SSD/HDD: 1 x 2.5" (without USB ports, the back-up button)
3) SSD/HDD: 2 x 2.5" and FAN 80,92,120 x 25mm (it is possible to install the button in front and USB ports)
4) SSD/HDD: 4 x 2.5" and FAN 80 x 25mm (it is possible to install the button in front and USB ports)
5) SSD/HDD: 6 x 2.5" (without USB ports, the back-up button)- PSU: SFX/SFX-L
- PCIe riser: LiHeat 300mm A.type
- RAM: up to 60 mm
case FX mini / mid
Order the Case with our modified Power Supply and get a unique look and maximum of silence with the Noctua fan
case FX mini 4.5L PHOTO ALBUM
Extremely compact case for travelers and connoisseurs of mini! Ideal for building a super compact, Gaming Mini PC. The complexity of installing components.
Specs:
- Volume: 4.5L (225mm x 190mm x 105mm)
- GPU: length <175mm, height <132mm (Giga 1080 Mini and MSI 1070 Aero ITX compatible)
- CPU Cooler: up to 39mm (Noctua L9i compatible)
- RAM: up to 42 mm
- Storage: M.2 and 1x2.5" SSD
- PSU: Flex ATX 1U Mini-ITX (Seasonic SSP-300SUG, FSP 400W, Athena Power 400W, FSP 500W Platinum etc)
- RAM: up to 42 mm
case FX mid 6.1L PHOTO ALBUM
A bit more and already inside is a super powerful video card and a big CPU cooler. Ideal for home entertainment! Easy installation of accessories.
Specs:
- Volume: 6.1L (225mm x 225mm x 120mm)
- GPU: length <215mm, height <132mm (ZOTAC GTX 1080ti mini compatible)
- CPU Cooler: up to 50mm (CRYORIG C7 compatible)
- RAM: up to 50 mm
- Storage: M.2 and 2x2.5" SSD
- PSU: Flex ATX 1U Mini-ITX (Seasonic SSP-300SUG, Seasonic SS-350M1U, FSP 400W, Athena Power 400W, FSP 500W Platinum etc)
- RAM: up to 50 mm
case M mini
Specs:
- Volume: 3.9L (115mm x 190mm x 185mm)
- MB: mini-ITX (170x170mm)
- GPU: length <173mm, height <132mm, thickness < 38mm Compatibility table
- Storage: SSD/HDD: 1 x 2.5" 5-9mm
- PSU: pico HDPLEX DC-ATX
Please fill this form if you want to make an order.
If the form is not available tell us. custommodsff@gmail.com
