The curved OLED for monitor will be way too expensive to even bother with it for the next 2-3 years.
Hmm, have they solved IR/burn-in problems?
Saw the LG OLED. It's indeed absolutely stunning. Tried to figure out if there's someway to use it as a computer monitor. However, the pixel structure is very visible from any likely computer distance. (A problem with all large low PPI panels I've seen, but maybe worse on the LG OLED. Some have attributed this to an extra large spacing of the pixel rows. Or something like that.) And a burn-in warning is still prominent in the user manual. Some have reported visible burn-in or at least bad image retention. Anyway, no indication I could find that this would be safe as computer monitor.
Samsung has tablet computers with OLED screens now, so maybe that is a sign of hope...
How about something that always is there of preset size? For example windows panel and alike? Of course, one can autohide that. One can switch background image .. but all of such sounds like ugly workarounds that worsens usage experience.
The LG I saw was 1080p and that is not acceptable for a monitor. You have to wait till curved displays are also 4K at a price you can afford. And of course you need to make sure it accepts at least 60hz input. I will be interested when a 32-55 inch 4K TV is available that allows me to use lightboost at 120hz or something comparable.
As for burn in, depends on how fast it takes place. I have been able to run plasma TVs for years without problem if windows and applications choices are configured decently.
You use plasmas as a primary PC display? (Pioneer? Think I heard of others using those plasmas with more success for PCs...at least as secondary displays. Think I read 30K life hours for LG OLED...which would be much less than the latter plasmas I think...)
You've probably heard another interesting display for PC use is possibly the upcoming Vizio P Series, which has 4K, LCD but with 64 zone local dimming, a 120 Hz 1080P mode, and a 50" model. Though until it's released, still big questions about the low zone count, motion handling, etc...
(As to the LG...forgot to mention earlier that someone also commented about the extra subpixel for white that LG introduced also leading to some aliasing of text or such...)
