Bigger diameter pipes have more volume for vapor movement from evaporator (base) to condenser (fin area) surface area and surface area in evap area of pipe and condenser area for heat transfer and wick surface area to wick coolant from condenser back to evaporator area.Question for anyone knowledgeable in physics: Is there any difference between having fewer but wider heat pipes (e.g. 8mm x 4 pipes) vs more but narrower heat pipes (e.g. 6mm x 7 pipes) ?
Could you mount fan in middle pulling air thru front tower and fan on back pulling air thru back tower, or just run single middle fan? I've found single middle fan on twin towers cools as well as 1x fan on twin towers at same noise level. Noctua says their NH-D15 (2x fans) only cools 1-3c cooler than NH-D15s (1x fan). That is only a full speed, because single fan moves a little less air at same speed than 2x fans at same speed, but speed up single fan about 50-100rpm to same noise level as 2 fans and they cool the same.Hey guys need your advice,
I have to cool a 5800x and 5800x3D
I picked up 2 PA 120s but they dont have enough clearance for the DIMMs I got. I don't want to mount the front fan higher or in the back. I tried and it looks weird
If I wanna keep this RAM, do I have to rule out all dual tower coolers?
If so, I guess I'd have to switch to a single tower cooler.... Any recommendations?
Also, about AIOs, CanadaComputers has DeepCools Castle EX240 for 79$ Canadian dollars. No issues with RAM clearance but I've never used an AIO before. Last rig I Watercooled was a custom loop that I didn't want to maintain anymore.
Im stuck
So if I understand this right, 8mm x 5 pipes would wick more heat away than 6mm x 7 pipes?Bigger diameter pipes have more volume for vapor movement from evaporator (base) to condenser (fin area) surface area and surface area in evap area of pipe and condenser area for heat transfer and wick surface area to wick coolant from condenser back to evaporator area.
Below shows the general idea. Keep in mind inside surface area is less because of thickness of pipe. Wick area is even less. Gravity effects wicking action too.
7x 6mm heatpipes = 131.88mm surface & 197.83cubic mm per mm vs 4x 8mm heatpipes = 100.48mm surface & 200.96cubic mm volume per mm
7x 6mm heatpipes = 131.88mm surface & 197.83cubic mm per mm vs 5x 8mm heatpipes = 125.6mm surface & 251.2cubic mm volume per mm
