Current 43" 4K options?
43" is such a neglected category, which no company does well, or is overpriced.
There isn't even a fuckin OLED in this size.
I think computer-worthy 43" will become extinct soon, and we'll have to move up to 49-50" to find anything decent.
Got the 49" MU6500. I much prefer this VA panel over the 43 MU6300. Blacks are so much darker. It was a PITA to calibrate, the SpyderPro software had no clue what was going on, but DisplayCal sorted it out after 45 minutes of chugging along. It's big, but not gigantic, the curve helps a bit with the panel size. 49" is a good size for a desktop monitor. Definitely wouldn't go any bigger though.
Surprisingly, I really can't tell much difference between a BGR panel and an RGB panel w.r.t OS X font smoothing. I think that issue is really over-blown.
Now to see if I can sell the MU6300 locally instead of boxing it all up again and shipping it back to Amazon. Hoping I have good luck since I got it for super cheap and just looking to get my money back.
Surprisingly, I really can't tell much difference between a BGR panel and an RGB panel w.r.t OS X font smoothing. I think that issue is really over-blown..
You sure not much difference?
I imagine it just looks a little fuzzy. But once you've seen tack sharp, the fuzzy is annoying. With my BGR screen, I had to change some Firefox 'azure' setting because it was rendering in RGB and ignoring cleartype, and the text looked pretty blurry.
So is the 49" much brighter than the 43" ? If you set an all white screen, what's the brightness setting decreased to in order to match the brightness of the 43" ?
Also, what's the measured color gamut and shit of the 49 ?
49" VA is much brighter.. I don't have them setup side by side, but I found 12 to be comfortable on the 43" IPS, and the 49" VA equivalent would be an 8. I'm ~ 2ft away in a very dark room.
Text really isn't fuzzy at all, it's really not much of a difference as far as font smoothing goes, at least for my normal, every day uses which is mostly Safari / Chrome, Mail, terminal. I'm surprised, I thought it was going to be a fontish mess, and so far I have yet to find myself sayin "oh, yeah. that's a font smoothing issue". Maybe it's just extra resolution with 4k helping, I came from a 1440p panel.
Gamut and more info (including EDID stuff) below..
Moral of the story as far as I'm concerned, it's good enough for sRGB work for me. The dotted line in the image is sRGB and the colored line is the monitor. This is all post calibration. Turning on UHD Color on the HDMI port and setting it to about 9 brightness and Warm2 got it pretty darn close to well calibrated.
Coverage info pasted here as it's all the way at the bottom and probably what most people might care about. 96% sRGB.
GAMUT_coverage(srgb) 0.9599
GAMUT_coverage(dci-p3) 0.7292
GAMUT_coverage(adobe-rgb) 0.7099
Code:
Size    741760 Bytes (724.38 KiB)
 Preferred CMM    0x00000000
 ICC version    2.4
 Profile class    Display device profile
 Color model    RGB
 Profile connection space (PCS)    XYZ
 Created    2017-12-03 18:40:21
 Platform    0x00000000
 Is embedded    No
 Can be used independently    Yes
 Device
     Manufacturer    0x00002D4C Samsung Electric Company
     Model    0x00000DF7
     Attributes    Reflective
    Glossy
    Positive
    Color
 Default rendering intent    Perceptual
 PCS illuminant XYZ    96.42 100.00  82.49 (xy 0.3457 0.3585, CCT 5000K)
 Creator    0x00000000
 Checksum    0x00000000000000000000000000000000
     Calculated checksum    0x2A2C7953A78D57AD4458D8B41D544C02
 Description (ASCII)    #1 2017-12-03 17-25 2.2 F-S XYZLUT+MTX
 Copyright    No copyright. Created with DisplayCAL 3.3.5.0 and
    ArgyllCMS 2.0.0
 Device manufacturer name (ASCII)    Samsung Electric Company
 Device model name (ASCII)    SAMSUNG
 Luminance    95.38 cd/m²
 Media white point
     Is illuminant    Yes
     Illuminant-relative XYZ    94.15 100.00  99.75 (xy 0.3203 0.3403)
     Illuminant-relative CCT    6053K
         ΔE 2000 to daylight locus    2.29
         ΔE 2000 to blackbody locus    6.10
 Media black point
     Illuminant-relative XYZ    0.0778 0.0824 0.0809 (xy 0.3228 0.3418)
     Illuminant-relative CCT    5934K
         ΔE 2000 to daylight locus    1.87
         ΔE 2000 to blackbody locus    5.86
 Video card gamma table
     Bitdepth    16
     Channels    3
     Number of entries per channel    256
     Channel 1 gamma at 50% input    1.06
     Channel 1 minimum    6.2501%
     Channel 1 maximum    91.80%
     Channel 1 unique values    256 @ 8 Bit
     Channel 1 is linear    No
     Channel 2 gamma at 50% input    1.08
     Channel 2 minimum    6.2501%
     Channel 2 maximum    91.80%
     Channel 2 unique values    256 @ 8 Bit
     Channel 2 is linear    No
     Channel 3 gamma at 50% input    1.08
     Channel 3 minimum    6.2501%
     Channel 3 maximum    91.80%
     Channel 3 unique values    256 @ 8 Bit
     Channel 3 is linear    No
 Device to PCS: Intent 0
     Matrix    1.0000 0.0000 0.0000
            0.0000 1.0000 0.0000
            0.0000 0.0000 1.0000
     Input Table
         Channels    3
         Number of entries per channel    2049
     Color Look Up Table
         Grid Steps    33
         Entries    35937
     Output Table
         Channels    3
 Red matrix column
     Illuminant-relative XYZ    44.93  23.51   1.91 (xy 0.6387 0.3342)
     PCS-relative XYZ    47.20  24.43   1.52 (xy 0.6453 0.3339)
 Green matrix column
     Illuminant-relative XYZ    33.07  70.18  10.77 (xy 0.2900 0.6156)
     PCS-relative XYZ    35.50  70.03   9.36 (xy 0.3090 0.6095)
 Blue matrix column
     Illuminant-relative XYZ    16.15   6.31  87.07 (xy 0.1475 0.0576)
     PCS-relative XYZ    13.71   5.55  71.61 (xy 0.1509 0.0610)
 Red tone response curve
     Number of entries    256
     Transfer function    ≈ Gamma 2.18 100% (Δ 1.77%)
     Minimum Y    0.0000
     Maximum Y    100.00
 Green tone response curve
     Transfer function    ≈ Gamma 2.20 100% (Δ 1.70%)
     Minimum Y    0.0000
     Maximum Y    100.00
 Blue tone response curve
     Transfer function    ≈ Gamma 2.18 100% (Δ 2.49%)
     Minimum Y    0.0000
     Maximum Y    100.00
 Device to PCS: Intent 1
     Input Table
         Channels    3
     Color Look Up Table
         Grid Steps    33
         Entries    35937
     Output Table
         Channels    3
 PCS to device: Intent 1
     Matrix    5.5553 -2.6715 -0.8303
            -1.9202 3.7670 0.1024
            0.1570 -0.4115 2.7399
     Input Table
         Channels    3
         Number of entries per channel    4096
     Color Look Up Table
         Grid Steps    33
         Entries    35937
     Output Table
         Channels    3
 PCS to device: Intent 0
     Input Table
         Channels    3
     Color Look Up Table
         Grid Steps    33
         Entries    35937
     Output Table
         Channels    3
 Characterization target    [23770 Bytes]
 Characterization device values    [23770 Bytes]
 Characterization measurement values    [23770 Bytes]
 Chromaticity (illuminant-relative)
     Channel 1 (R) xy    0.6387 0.3342
     Channel 2 (G) xy    0.2900 0.6156
     Channel 3 (B) xy    0.1475 0.0576
 Make and model
     Manufacturer    0x4C2D Samsung Electric Company
     Model    0x0DF7
 Metadata
     prefix    EDID_
    CMF_
    DATA_
    MEASUREMENT_
    OPENICC_
    MAPPING_
    ACCURACY_
    GAMUT_
     EDID_mnft    SAM
     EDID_mnft_id    19501
     EDID_model_id    3575
     EDID_date    2017-T1
     EDID_red_x    0.640625
     EDID_red_y    0.330078125
     EDID_green_x    0.30078125
     EDID_green_y    0.6005859375
     EDID_blue_x    0.150390625
     EDID_blue_y    0.060546875
     EDID_white_x    0.2802734375
     EDID_white_y    0.2900390625
     EDID_manufacturer    Samsung
     EDID_gamma    2.2
     EDID_model    SAMSUNG
     EDID_serial    16780800
     EDID_md5    440b222040c3443601a579660391ea57
     CMF_binary    DisplayCAL
     CMF_version    3.3.5.0
     CMF_product    DisplayCAL
     License    Public Domain
     Quality    high
     OPENICC_automatic_generated    0
     DATA_source    calib
     MEASUREMENT_device    spyder4
     MAPPING_device_id    xrandr-Samsung-SAMSUNG-16780800
     ACCURACY_dE76_avg    0.264213
     ACCURACY_dE76_max    1.903997
     ACCURACY_dE76_rms    0.364691
     GAMUT_volume    1.03367455123
The E43 has a lower list price, so I bet it's the same shitty display.
It's just dithering. This is how cheapass TVs dither to show colors. It's a form of static dithering, as described here http://www.lagom.nl/lcd-test/black.php
yes, the dot matrix dithering is common among crappy cheap budget TV's.
mid range and higher end TV's don't have this ugly shit. The only cheap 43" TVs that do not have this ugly pixel dimming are the Samsungs and the TCL 43" S405.
The TV's that have this ugly dot matrix include the 49" and 55" TCL S series, cheap 50" Sharp, 55" TCL P605/7.... Insignias, Toshibas, and other cheapass TVs.
showing dark grays with ugly dots. This one is from the TCL P605, but other crap TVs have the same effect...
as you can see close up, it turns off every other subpixel to render some colors, and this is what makes it look like shitty dots.
Thank you so much for this info! I just picked up a 55 " TCL 55S405 and the dithering basically makes it unusable as a monitor. I was going mad trying to tweak various setting on the TV and on the PC to no avail. I'm planning on returning it and instead picking up a 49" Samsung 49MU6290. Do you think it would be prone to the same dithering effect? I could also reluctantly go down to the 43MU6290 or 40MU6290 if they are far superior for monitor use. I've read through the thread and it seems that both of those are good- just pick your poison between an IPS or VA panel.
Unfortunately those are likely the only options in my budget (though the TCL 43S405 is an option if I wanted to give TCL another shot). My use case is a screen to serve as both my TV and PC monitor in my small studio apartment. I would use it as a monitor on my desk and as a TV when viewed from my bed. I'm thinking 49" would be the sweet spot for this but that dithering stuff is really scaring me off from going big.
None of the samsung 6000 series TVs has that shitty dot matrix dithering, so you're safe.
The TCL 43s405 does not have dot matrix either, however, it's not perfect. On still images, it's pixel perfect.
In motion video, sometimes you see fine vertical lines because the temporal dithering it uses doesn't have high enough frequency. It's an eye illusion really. Many TVs that use an AUO panel have this to some degree, especially Vizio, but the 43s405 has a greater degree of it.
I'm in contact with TCL to try to get it fixed with firmware, but I'm not too optimistic. Most people probably wouldn't notice because they don't have a high quality TV to compare to.
I ended up keeping the TCL 43" despite its shortcomings. For $252 net after all discounts perks and taxes, it's the best bang for the buck for a big pc monitor.
nice, so it's a little more, a little less, than sRGB.
good enough.
Yep, I think it's probably very close to full sRGB, moreso than my tests report. You can see where my test reports 72.92% dci-p3 coverage, I think rtings had 75 or 76%.. they use a $7,000 device with pro-level software that costs quite a bit. I use a $150 consumer calibration device with free software, so clearly they're going to be more accurate. I'm betting falling short of 100% sRGB is more on my testing than the actual panel's capabilities.
Cool! I'll try my luck with a Sammy. Yeah the TCL deals were awesome. Did you do the Target 15% off + 5% off RedCard? I wish I'd known about the dithering thing before that sale. I figured the upgrade to the 55" for $340 net would be worth it. And boy was i wrong
i did the target deal, plus 10% cash back from Discover.
Right now, the 40mu6290 always sells for <$300.
Sometimes the mu6300 is even that price.
If you can get it tax free, not a bad deal.
If you can get 4:4:4 and a clean text pattern with this years 6290... not gonna happen. ... without a lot of work, if it’s at all possible.
I’ve had 43” tcl’s from 2 different retailers, both have what we used to call b-grade panels.
Trying another approach, the 40” curved VA panel from AUO is on sale at Best Buy again from $499. Time will tell
FWIW.
FWIW.
I only have the 6300, but I assume the 6290 is identical picture quality.
It has 4:4:4, but what do you mean clean text pattern?
I know the Hisense has some fucked up text rendering which Hisense won't fix with firmware, but the samsung doesn't have that kind of problem.
Looks the same to me...
TCL....
Samsung 40mu6300
Ended up getting Sony 43X720E during black friday sale from walmart.
Got it just for a TV without PWM flicker. I can confirm the TV is as comfortable on my eyes to use as my Dell IPS PWM-free monitor. 1" away to 20 feet feels great on my eyes. The Sony is unbelievably bright which I had to turn all the way down to 5/100. I can definitely see why people are using these as monitors as the Sony's performance is very hard to tell the difference with my regular Dell monitor.
Sorry this isn't technical but for those that need a larger flicker free TV/monitor, there is literally not any options so beggars can't be choosers in this regard.
Reactions: HA5
Rtings reviewd the 43x720e, and measured only 340nits, and inline with other budget samsungs and LGs.
That's not unbelievably bright. It's just like an above average laptop screen, which is typically 300nits.
If you turned it all the way down to 5/100, that must be dim as fuck.
Also, the TCL 43" is pwm free at 100% brightness.
Samsung 6xxx series TVs are also PWM free all the way down to 13/20 brightness.
I went to best buy and looked at the Vizio 43" E series, and it has the same shitty pixel dot matrix color rendering as the D43 series.
They're both the same shit quality
Same goes for the Sharp 43" Roku TV at bestbuy.
Just to refresh your memory, this is "dot matrix" color. Fuckin yuck...
I don't have BFI on or anything that dims the screen. 25/100 and below really don't change the brightness that much. I guess to me and for my application it is brighter than I thought it would be.
http://i.rtings.com/images/reviews/mu6100/mu6100-motion-blur-large.jpg
http://i.rtings.com/images/reviews/mu6300/mu6300-motion-blur-large.jpg
http://i.rtings.com/images/reviews/mu6500/mu6500-motion-blur-large.jpg
vs
http://i.rtings.com/images/reviews/x720e/x720e-motion-blur-large.jpg
Samsung 6xxxx series is atrocious at motion with trailing/doubling images. That kills my eyes. TCL is similar. Having a monitor/TV where if I lower the brightness enough to activate the PWM is kind of pointless since that would limit my ability to use said display. I'm only recommending Sony for people that experience issues with eye strain using LED screens.
vs
Best Buy has the 40" AOC C4008VU8 on sale for $499. My order arrived for pickup and I've set it up ias my primary work display, replacing the Seiki 39 30Hz 4k.
Initial thoughts... Wow.. I'm impressed. This display clearly is in a class above the Samsung 6 series and TCL 43S405.
Pretty tempting. If it had freesync and faster pixel response times I think I'd be all over it. I sent back my Samsung 40" MU6290, loved the size as it was perfect, but was not loving it enough to keep it as a monitor.
in what ways exactly?
I can't tell from the specs. All i can tell is they gave it some overdrive to reduce response time by a lot.
I only care about image quality.
it looks like a clone of the philips 40" curved monitor. probably exactly identical inside.
Well to start with, the samsung 6290 has red and blue over bleed, making it look more like a 4:2:2 than a 4:4:4
The pixels on the AOC are sharp. Across the, aroma test, lines below and all. FWIW.. Image quality looks better than my Crossover 324k's 10-bit panel.
A couple of quick pics from the aoc
Did you set the samsung to BGR in Windows and turn off sharpening?
Bleeding sounds like what you'd get if you tried to run RGB on a BGR screen.
Well, I'm not running in windows.
On the samsung, sharpening set to 0, displayed at 3840x2180 at a 1:1 pixel ratio. If I turn the color down drastically, bleeding goes away and the pixels are clean. Would be a deal at $300 if it was 4:4:4.
Compared to the TCL.... Well, both of my TCL's had what I would consider a B-Grade panel - resulting in both returns. Light color or grey backgrounds were a streaky mess from poor quality lighting. My second display developed two vertical hotspots over time about a 1/4 screen from center, 1/2" wide and 1/4 screen tall. Overall the TCL is still a killer value, it just has a couple weak points.
you're not running Windows... that's likely why.
I wonder if this philips/aoc has an RGB subpixel array. If you can take a clean pic zoomed in, you could tell.
That would give it a clean image in everything outside of Windows.
I'm 99% sure the samsung is 4:4:4. Anything other than 444 would result in garbled text, not just overbleed.
I wish you could take a pic of the chroma image on the 6290 if you still have it.
Here's a pic of my TCL subpixels on the chroma444 image. Red and blue are confined to their own subpixels, so there should be no overbleeding, if you look at it under a macro lens.
if the red subpixel is overbright and overpowering the blue subpixel right next to it, that would make it look like overbleed. Probably would have to tune the reds.
I have no complaints on the TCL's 4:4:4. It's a solid display path from AUO. I'll take a pic of the sammy after work
I have last year's Samsung (I think the 6300?) and while I like the input lag when run in game mode and the overall picture quality, I find the grey-to-grey response time to be pretty horrible. Any of these 2017 models make a decent PS4 Pro and PC gaming monitor with 20 ms or less input lag and actually good grey to grey response time? I just wish LG made an OLED in 43 inch size, I'd pay allot for it.
First off, registered just to thank everyone that posts about monitors, especially Commander Shepard and kdawg, among others. I've been looking to replace my Dell 3007, and got both the LG 43" and the Sony X720E 43".
Both were a huge upgrade from my Dell, and OMG, the colors on my Dell were so off when I hooked one of the 43"s up next to the Dell. The Dell was way dimmer as well, do CCFL backlights degrade? Either 43" monitor is a night and day difference over my Dell. I'm using it at about 3feet away, once I decide what I keep, I'll be getting a desk mounting pole to put it on, but for now they are just sitting on my desk.
Picture wise, I thought they were both comparable, perhaps the Sony was a bit better. But I didn't do a real calibration, so take that with huge grain of salt.
The real difference is the PWM on the LG. I believe it has the latest firmware, from comparing posts here, but I still think I noticed the PWM backlight. Every time I used it, I would get eye tension, not really a headache, but that weird, tightness around my eyes. I never got it with the Sony. I've swapped monitors back and forth a few times, and every time with the LG I feel the eye strain. I'm running my desktop at 150% so it isn't that the text is too small either.
The only real PITA with the X720 is that when starting the monitor in gaming mode, you have to manually switch to another mode and back again to get the low latency. This glitch is mentioned on the rtings review page of this monitor, and you can definitely tell it.
Now I am trying to decide if I return the X720 for the X800, just so I don't have to keep swapping modes back and forth. Any other benefits to moving to the X800E?
Reactions: HA5
What was the BF price for the 43X720E? I was very impressed with the overall picture of the 43X720E in comparison with every other sub 50" TV around it at Best Buy.
Wider color gamut and slightly higher maximum brightness, but it doesn't have as good viewing angles.
x800E is the 2017 model , x720e is a 2016. 800E will have the latest firmware updates.
800E has the triluminious Display , which means many things but it has the bigger color gamut , to me the display feels a bit more vibrant than the x720e not sure why...
As far as the viewing panels, ii didn't notice any difference.
however the 800E has that annoying android software installed which is a big nuance , and i feel is probably some of the reason why it causes noise and other issues with the display.
so all in all, for 50 $ bucks is well worth to get the 800E over the 720E, seems like Sony worked out a lot of the bugs from the 720E, if you look at the reviews are a lot better for one over the other.
This is widely reported but I have dismissed at first since LG upped the PWM to 480Hz. Original 120Hz was unbearable from the start, 480Hz is masking it pretty well and if you can use the monitor with brightness >75 or so than it, probably, is not an issue. This is a great monitor, btw in terms of colors, size and unique split-screen. Unfortunately, even though I got 43MU79 (LG 43UD79 and Dell P4317Q use similar PWM too) for great price and loved PBP I could not keep it.
I have a room with controlled lighting and usually ended up with brightness between 30-60. After a week of using it (8 hours/day) I begun having headaches (in front of the head) and my eyes were 'jumping' when reading on my phone (that one was really weird).
I think large screen area is magnifying the flicker issue. Smaller monitors are probably fine at 480Hz but 43"monitor will shine light from angles - at corners of one's eyes - where optic nerves are more sensitive to flicker.
Rtings supports your findings.
They reviewed the 43" x720e, and the results were pretty embarrassing.
only 8 bit color, not even FRC?
embarrassing color gamut, with dci-p3 73/79%
embarrassing contrast.
In comparison, the shitty TCL 43" with the AUO panel has 8bit+FRC,
dci-p3 color gamut 81/87%
Most TVs don't have that overdrive that pc monitors have.
I notice that they all suck when it comes to response time, as tested at http://www.lagom.nl/lcd-test/response_time.php
The 43" TCL does better than Hisense, but worse than 43" samsung mu6300 IPS.
I don't have my 40" samsung 6300 anymore, but I remember response time was also worse than the 43" samsung
IIRC::
x720e has lower input lag
x800e has android TV + better speakers + TriLuminos Display + 10 bit color
KD55X720E $598
KD49X720E $528
KD43X720E $478
Absolutely insane price but there is literally no other option for people who need flicker free screens. Sony controls all prices across every authorized dealer.
