BellaCroix
- Mar 25, 2004
Let me preface this by saying I'm not planning on doing it, but I was sitting around pouring rubbing alcohol on a cut and my mind started wandering...
Has anyone ever used Isopropyl Alcohol in a water cooling loop? What advantages/disadvantages could you forsee. I know the 50% solution's boiling point in 180°F, flash point is much lower but without an ignition source that shouldn't be an issue (Okay, I have too many MSDS at work that I read on lunch when I'm bored).
Yes, I know the cold feeling you get when you put it on your skin is caused by it's rapid evaporation and that wouldn't play a part in a loop (unless a bong set-up would work). It should kill nasties in the loop, but I think it's electrically conductive, right... so it would do nothing to stop corrosion?
Just curious.
Just curious.
