- Oct 29, 2000
I've never used one of Creative's sound cards that have the 24Bit Crystallizer option. How do you like it?
As I understand it, it uses a series of complex algorithms to attempt to revert the sound to a pre-CD mastered state. To me it sounds like black magic. Sort of like in the movies when they zoom in on a video and then "enhance" but I'm not going to write it off completely, at least not without testing it first.
How I have understood things:
The crystallizer mitigates compression. Not file compression (like compressing a wav file to mp3) but dynamic range compression.
As I understand what happens is that big recording studios figured out that they get more radio airplay out of music that is loud, but in the 16bit space of the CD, there is only a limited number of different "volume levels". So what do they do? Once they are done mixing the track, they lower the volume of all the peaks to about the average volume, and then raise the average volume to 96% of the output, creating music that is evenly loud throughout the track.
Why this is good:
The song is now louder. Louder music gets more attention on the radio and sells more albums.
Why this is bad:
With the volume peaks less distinctive than they were before cymbals and bass drums sound less punchy, energetic and clear. Background sounds that sound quiet during loud parts of the track, suddenly get louder during quiet parts of the track.
The crystallizer apparently tries to revert the output sound to something more similar to what it sounded like prior to the compression into the 16bit space of the CD, and then plays it over the 24bit outputs of the sound card.
My question is - thus - does it work? I would find it difficult to believe it can work well, but if it does I am interested in checking it out...
Why this is good:
Why this is bad:
