Crysis - DX9 vs DX10?
defiant007
Just installed Crysis the other day on my new machine which currently has XP SP3 installed. On high details at 1900x1200 the frames are silky smooth and awe inspiring, but then again I am easily impressed having upgraded from a 6800GT to a GTX 280.
Is there any significant eye candy I am missing out on by only playing the game in DX9? I am not really keen to install Vista just for one game (although WiC apparently is quite impressive in DX10). Also, the config menu will not allow me to select "very high" for the detail levels. Am I correct in assuming that you can only select very high if you are running DX10?
Search for Crysis DX9 "very high" settings hacks for Windows XP. They are special config settings that allow you to add many of the extra graphical features found in the DX10 version.
And yes, WiC is very impressive in DX10 ;)!
orengable, you press the "post reply"-button only once, not four times!
The site has been lagging big time lately. This is the cause of all the double, triple posts.
Sorry about that, I thought something froze, and accidently held the post button down a little too long. How do you delete posts?
The crysis "ultra high" mod/config found at crymod makes crysis really beautiful.
Yeah, it's odd there seems to not be any way to delete your posts.
It hasn't been lagging for me, and if I was a mod, I would delete those extra posts without further notice...
the forum has been lagging for tons of people. just look in the forum help section and see for yourself.
Yup, that'll get you close so that you probably won't miss too much. That said, I upgraded to Vista 64 about two weeks ago (primarily for the 64-bit address space, not DX10), and there is a noticeable difference in the DX9 "copy Very High to the High section" settings and native DX10 Very High, usually in the lighting. The jump isn't as big from Medium to High or from High to DX9 "faux Very High", but it is there. Also, motion blurring is better under DX10, IMO.
I wonder if the 4870 still performs better under DX9 like the 3870 did.
Both vendors perform better under DX9, but the GT200s seem to take a bigger hit going to DX10 vs the HD4000s (with the newest driver).
DX9 of course makes Crossfire work splendid though.
i tried the very high settings hack for xp and it didn't work. meh i guess i did something wrong. i'll try it again when i get my 4870x2 :)
I use DX9 with the ultra high config, and it looks gorgeous. Course, I barely get above a constant 20fps with my 8800GTS that way, so I play in small spurts, wetting my appetite for the 4870 in my future.
the 4870 isnt going to make those settings much more playable.
Meh - can't see what was wrong with DX6 me self *sniff* ruddy whipper snappers don't know your born! ;-) Now where'd I put me teeth ...
Anyhoo back to the post I just never bother with DX10 just too much of a frame rate hit on my 8800GTS 320 MB (CoH, Crysis & WiC) card and the visual improvement isn't worth it if the game is unplayable.
Now looking forwards to the arrival of my Power Colour 4870 to see if things improve in the DX10 department.
you only have 320mbs of vRAM......
