I might be wrong, however, I believe you must have a cross fire x compatible board first.
Joe
Even on a SLI board with NVidia chipset?If you have a motherboard with 2 PCIe slots, you can utilize CrossfireX by running two 3870 X2's..
If you have a motherboard with 2 PCIe slots, you can utilize CrossfireX by running two 3870 X2's. As for a single chip solutions (i.e. Three 3870 videocards), you would need a board that is crossfire compatible and has the available PCIe slots.
That's wrong, you still need a crossfire compatible motherboard if you want to run crossfirex
However, you can run the built-in crossfire (transparent crossfire) on a single 3870x2 on any motherboard.
source?crossfire x needs a compatible motherboard, crossfire x referring to running 2 different video cards in the same motherboard
