Critque/recommendations on a build
Status
Not open for further replies.
FearTheCow
I had been thinking of getting a laptop, but am pretty much decided that a SFF would be better for now, with that said..
Word processing, web browsing, quick books, light gaming.
$700, including shipping
U.S.
4) What exact parts do you need for that budget? CPU, RAM, case, etc. The word
"Everything" is not a valid answer. Please list out all the parts you'll need.
Motherboard, CPU, Ram, HDD, Monitor, power supply.
Case
6) Will you be overclocking?
Maybe
1080p, 18"+
Within 30 days
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video (as a backup or main GPU)? etc.
One that fits in a SFF case.
I will be buying Win7 home.
Here is what I have come up with so far:
21" monitor, $144 - http://www.newegg.com/Product/Product.aspx?Item=N82E16824236176
Motherboard, $85 - http://www.newegg.com/Product/Product.aspx?Item=N82E16813131769
CPU, $130 - http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.830955
Memory, $60 - http://www.newegg.com/Product/Product.aspx?Item=N82E16820231460
SSD, $104 - http://www.newegg.com/Product/Product.aspx?Item=N82E16820148441
OS, $100 - http://www.newegg.com/Product/Product.aspx?Item=N82E16832116986
Grand Total: $623.95 +shipping, I picked newegg due to ease of finding products, will search for cheapest prices possible when the time comes to order.
What case will you be reusing?
Did you need a DVD burner?
By HDD, did you mean SSD or SSD + HDD?
64GB is a good starter size for the OS, you will need something bigger for games and such.
I have a PSU, DVD drive, and case to use for now, the SSD should be more then enough space for the foreseeable future.
Gonna ask again: What case will you be reusing?
Also what PSU will you be reusing?
I was going to use a POS full tower case, but have decided to get one of the following instead:
SS PS07 - http://www.newegg.com/Product/Product.aspx?Item=N82E16811163186
SS TJ08 - http://www.newegg.com/Product/Product.aspx?Item=N82E16811163182
Fractal Design Arc Mini - http://www.newegg.com/Product/Product.aspx?Item=N82E16811352008
and a 5 year old 500w PSU, not feeling like digging it out to remember the brand.
So are those cases part of the budget? Really need to know the make/brand of PSU you plan on using before we can recommend you parts. The PSU is the most important part of your system, many people look past this; but with a substandard PSU it could destroy all of your components should it go out. Seeing as how it's ~5 years old, I think you'll want a PSU as part of that budget.
I have tweaked a couple items and am now at less then $600 for everything I need, thanks for the "helpful" advice:rolleyes:.
Status
