I posted this in the "build your own intel/amd" thread on slickdeals, but got no response. So I'm hoping you guys can [H]elp me out! I'll just copy the post here if you don't mind. thanks.
Code:
[B] 1. Do you have a Frys or Microcenter nearby?[/B]
no
[B] 2. What is this PC going to be built for?[/B]
linux file server. Also run multiple virtual machines to use as a desktop
I'd also like to play L4D and L4D2, but I don't know how gaming on virtualization has gone so far so I'm not sure about investing in a graphics card
[B] 4. What is YOUR budget?[/B]
around $400 total
[B] 7. If YOU intend on using any of YOUR current parts?[/B]
* APEVIA ATX-AS520W-BK 520W
* 1 PATA 250GB HDD, 2 250GB SATA HDD, 1 1TB SATA HDD
[B] 8. If YOU plan on overclocking?[/B]
yes
[B] 9. When do you plan to build it?[/B]
within the week or two, depending if its worth the wait. Of course I'd like it asap
Code:
Sony Optiarc 24X DVD/CD Rewritable Drive Black SATA Model AD-7240S-0B
$23.99
Antec Three Hundred Black Steel ATX Mid Tower Computer Case
$54.95
G.SKILL 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit Desktop Memory Model F2-6400CL5D-4GBPQ
$84.99
AMD Phenom II X4 925 Deneb 2.8GHz Socket AM3 95W Quad-Core Processor Model HDX925WFGIBOX
GIGABYTE GA-MA785GM-US2H AM3/AM2+/AM2 AMD 785G HDMI Micro ATX AMD Motherboard
$194.98
cirago BTA-3210 USB 2.0 Micro Bluetooth Dongle support Bluetooth 2.1
$14.99
COOLER MASTER R4-L2S-122B-GP 120mm 4 BLUE LED LED Case Fan
$9.98
Subtotal: $383.88
all from newegg. But I don't know if there are better deals for specific things from other sites
