so far here's what I'm planning to go with:
Mobo: Asus P8Z77-V Pro I chose this board as it seems to be the best board with a PS/2 port and intel nic onboard.
Ram: 16GB (2x 8GB) Corsair 1600 cas10 (unless cas9 makes a substantial difference)
Power supply: Corsair 650-850watt AX or HX series. still deciding on this...
Video card: Going to just bum around with the onboard for a little while until I do a bit more research on video cards.
Gaming with high quality settings @ 1920x1200, hypersurfin (50-70 tabbs open in firefox/chrome at a time), Photo Editing and Virtual Machines (Linux/UNIX, Windows8 beta, etc...).
For this half of the build (no video card at the moment) $500-650
Baltimore, MD. USA
Motherboard, Ram and power supply
i7-2600k, Antec p180, Monitor, 256GB samsung 830 SSD (sata6) and 2TB HDD
6) Will you be overclocking?
not right away, however I will be in the near future.
24" Dell, 1920x1200
within the next week or so
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video (as a backup or main GPU)? UEFI? etc.
SATA 6Gb/s, Intel nic built in, PS/2 port, SLI support, Onboard video with DVI output to start with (I'll be choosing a video card next month or two), UEFI Bios.
Yes, will be using windows 7 pro 64bit that I already have.
Baltimore, MD. USA
24" Dell, 1920x1200
